Results 1 to 11 of 11
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    S4 doesn't REVERSE! Please Help!!!
    don't know wtf is going on. The shifter will go in reverse, but pulls forward! Just started happening today after I changed the coolant temp sensor? All other gears work fine and I can go into reverse just fine, but the reverse lights don't turn on and the car pull forward like i'm in 1st gear, but more of a 5th gear pull? I have a jhm shifter and I just filled up the tranny fluid after replacing the output flange seal last week. Is there a fuse or switch that lets the car engage in reverse? I would think so since the reverse lights don't come on when in reverse? Please let me know anything I can do. Thanks!
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    Re: S4 doesn't REVERSE! Please Help!!!
    i read on something like this before.. has to do with umm something shifting off in the shifter area.. so .. when u put it in reverse it accually off track and going in 4th..u know?.. shift it back into place.. donno how or what not.. hope that helps.
    May 23 2008
    Columbia, SC
    spent an hour trying to re-adjust it and still nothing. When looking at everything...reverse looks like it is going into itself. All other gears look different, but when I push down and put it in reverse I can also put it in second, so it is definitely going in 1st instead of reverse.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Uh oh... did you use this hole to fill up the tranny?
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    You didn't install the shifter centering spring did you?
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    oh boy, these both could be bad
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Oops!
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    o shizzzz
    I didn't have reverse for about a month, but that was just becasue of my lack of skillz in shift assembly. I had to Fred Flintstone it everywhere. So I thought that mayyyybe you had done the same thing, but if you did this, that sucks! good luck in fixing it dude
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    May 23 2008
    Columbia, SC
    didn't use that bolt to fill the tranny...followed Bentley guide. and what is a centering spring? Reverse has been engaging fine for the last 5 months after install of jhm shifter. This happened out of no where.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    its all shifter alignment man, same thing happened to me but i knew what it was. you have to find reverse while aligning it. when u try to pop it down and move it to reverse your only going in first, when u installed the short throw you didnt tighten those to rods that connect to the tranny as tight as they should have been. when it happened to me ( driving about 5k or so miles with the jhm shot shifter) it kept only goin foward i couldnt grab the reverse, i quickly realigned it and BAM it works! lol seems like ive been on a run on sentence or some shit lol
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    May 23 2008
    Columbia, SC
    i got it...it turns out that the shifter wasn't dropping far enough down to engage reverse. It just kept bottoming out so I just added another set of washers to the 4 outer bolts that hold down the assembly. Still trying to align it though! Thanks for the help guys!!!
