Results 1 to 10 of 10
    Senior Member One Ring
    Oct 13 2007
    Need Fuel Filter Help
    I'm halfway done with replacing the filter. I got both the fuel lines from the rear of the car out and into the new filter but can not get the two hoses towards the engine. I've tried finger squeezing them, pliers, etc.
    I'm talkin' about these hoses. (Took this picture from another thread.) Its 10PM over here, need help ASAP. Thank-you.
    Feb 17 2005
    Sarasota, FL
    Re: Need Fuel Filter Help
    You gotta push the tabs in on each side and they will pull off.
    Oct 13 2007
    Quote Originally Posted by A4ringedONE8T View Post
    There doesn't seem to be any tabs on the ones pictured above or on mine.
    Feb 17 2005
    Sarasota, FL
    Yes there are, you can see them in the pic you posted
    Feb 17 2005
    Sarasota, FL
    The one on the bottom right of the pic you posted looks broken where you would normally push in
    Oct 13 2007
    Pressure at A or B?
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    When you squeeze them, push twards the filter, then pull off. HTH
    USP CLUB MEMBER #686
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Quote Originally Posted by Grenade View Post
    ^x2. do it just like that. dont over think it. just squeez it hard, push and pull. thats al there is.
    Jun 08 2008
    Calgary AB Canada
    Theres no tabs on the ones toward the engine. I did this yesterday.
    Theres just a 1/2 ring right at the end of the clip (point A) that you squeeze with needle nose pliers and pull them off
    Oct 13 2007
    Quote Originally Posted by onceover View Post
    Thanks. Will give it another try tomorrow morning.
