Results 1 to 2 of 2
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    Can't fillup with gas
    Can't fill up at the pump as there is to much pressure inside
    I have the following codes from Vag
    17818- this one is related to the purge valve, something like short to +
    16825-This one has to do with incorrect flow.
    I assume a new purge valve, is there any way to test them to make sure its not a wiring issue.
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Re: Can't fillup with gas
    You'll have to replace the charcoal canister as well. The only reason those valves go bad is from getting clogged up by charcoal. You can replace just the valve, but that valve will get clogged too, eventually.
