Results 1 to 11 of 11
    Feb 24 2004
    Minneapolis
    Huge Auto Transmission leak
    96 A4 Q with the V6. 5 Speed automatic transmission (01v). Transmission fluid came pouring out last night...no warning. Barely made it home. Get under it. I see no leaking in the cooling lines that run from the radiator. Fluid all over the pan...way up front on the tranny. I might guess front seal or touque converter area? But a seal would start leaking gradually, not all of the sudden....right?
    Any ideas of where fluid would just suddenly drop out of the car?
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    Re: Huge Auto Transmission leak
    are you sure none of the transmission lines that go to the rad are broke? I find it VERY strange that it would just dump all the fluid like that. I'm not saying it can't happen because anything can happen. next question. are you sure its ATF from the transmission and not the front differental? check that also
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Feb 24 2004
    Minneapolis
    Yea Blacka I'm sure on both accounts. I also find it very strange that it would just dump all it's fluid like that. But I asked a tranny shop and they said sometimes when a seal leaks just a bit, the pressure of the hydraulic fluid rushing past just blows the seal right out. I'm taking out the tranny right now. Looks like the leak is from the front (think front seal and/or torque converter) but I see nothing around the cooling lines to the radiator.
    Dodge RAM 1500
    Pittsburgh Area
    hum. it could be like you said the front seal or maybe the Tq converter seal which I know has been known to fail due to bad design
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by blacka4 View Post
    Yea I've read they redesigned that seal...and the new seal was only marginally better.
    Now I've got the tranny out and can't get the torque converter out. Bentley says to be careful it doesn't fall out...I can't pry the damn thing out!
    Dodge RAM 1500
    Pittsburgh Area
    umm its its anything like a domestic auto (which its probably not)you should have to twist the converter counter clockwise about 5 to 10 degrees then pull. I have not had mine apart and the only auto exp I have is with domestic autos.
    Feb 24 2004
    Minneapolis
    Going to try again blacka. Here's all our friends at Bentley say about putting one in:
    • Slide in converter hub through the sealing ring up to the first stop.
    • Rotate torque converter inward with light pressure, until the groove of the torque converter hub engages in the coupling plate of the pump wheel and the torque converter slides inward noticeably.
    So removal must be the opposite...but nothing about which direction to turn.
    Dodge RAM 1500
    Pittsburgh Area
    yeah the rotation inward is what I was talking about only in reverse. good luck
    Feb 24 2004
    Minneapolis
    But if the torque converter is just a big fluid clutch, when you rotate the outside the shaft on the inside is just sitting still isn't it?
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Did you figure out what it was?
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by 2.slowT View Post
    Yep. The pump went bad....it's right behind the front seal. When it went bad it slid around on its shaft and banged against the main seal and ruined that. So all 10 qt of fluid pumped out in about 2 minutes.
    Had to have the whole thing rebuilt.
