Results 1 to 6 of 6
    Senior Member Three Rings cpu77's Avatar
    Feb 27 2004
    Mansfield Ohio
    Carbonio filter replacement
    Ok I bought a like new carbonio CAI from a board member. When I got it I realized the filters glue has pulled apart from the plastic. Basically it sucks in dirty air! This is a 2.5-3" hole! Not to mention the guy spray painted the metal peices! WOW when will I learn to not buy like new parts!
    So where can one buy just the filter?
    Thanks
    Ralph
    Current
    2004 Silver A4 1.8T FWD 5spd Franken Turbo/3"Exhaust/Racewerks FMIC/440cc/Motoza/TestPipe/SAI Delete
    2004 Red A4 1.8T FWD 5spd (Wifes) Mods- Stage 1 Plus APR w/Neuspeed Exhaust/Test Pipe
    2002 Black Porsche 996TT X50 UM Stage2 Z/C k16/24 528AWHP
    1999 Wrangler 4.0 5spd/2.5" Lift 33" Tires No doors No top!(I like driving this better than my 911)!
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Carbonio filter replacement
    Sounds like it's not so new. Try Carbonio or one of their retailers.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    replace it with a pipercross or AFE element.
    Veteran Member Three Rings KrUsTyX's Avatar
    Feb 05 2007
    1982 VW Caddy
    Quebec, Canada
    contact carbonio directly, they will sell you the filter
    2006 Audi A6 Avant
    Arctic White
    Premium, Tech and Cold Weather packages
    VWQuebec.ca
    Registered Member Two Rings ben light's Avatar
    May 26 2008
    2003 Audi A4, 2007 Mini Cooper
    Dover pa
    Call AP Tuning. they are the exclusive Carbonio distributor in the US.
    _____________________________________________
    2003 Audi A4
    Giac Flash, FX Fuel Injectors, Forge DV, Magnaflow Exhaust, Carbonio intake, Eibach lowering springs, Color matched Mille Miglia 18" wheels, Vizage front lip, Erebuni wing and grill, Full Sherwood dash kit, AWE pedals, a little bump in the trunk.
    www.cepavw.org
    we roll deeper
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
