Results 1 to 4 of 4
    Senior Member Two Rings medracr's Avatar
    Mar 01 2004
    2006 A4 2.0T S-Line
    Los Angeles, State of Confusion
    Help with Problem
    Hey guys-
    I drive a 2006 B7 S-Line, lowered with Stasis SS coilovers, running ECS Porsche Big Red brakes, behind 18" S-Lines w/ 8mm spacers.
    Since last week, I've noticed that there is a "grinding" coming from my right front when I brake. Any ideas?
    Also, I've noticed since yesterday, that, also when I brake, there is a clicking/rattling sound coming from left front suspension.
    And, when I stop driveing and turn off ignition, theres a clicking sound as the fan winds down
    Any help would be appreciated!
    Last edited by medracr; 08-24-2008 at 03:07 AM. Reason: cant tell my left from my right
    "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, Cuban cigar in one hand, martini in the other, body thoroughly used up, totally worn out and screaming 'WOOHOO! What a ride!' "
    -Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!- Jonan
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Re: Help with Problem
    One thing is that the brake pad might be rubbing. I would also check that the brake pad hasnt completely gone away ASAP.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    DUH! an Audi
    los angeles, CA
    very strange, clicking sound from brakes can mean its too low, not tight enough... Rotor could be damaged...On my old b5, one time my caliper was loose and I heard tons of grinding noise when braking and it caused my pads to have uneven wear and cause damage.
    I would suggest jacking up car and looking at pads, see how much life they have left, also check for any abnormal wear on rotors.
    The fan might be normal, I hear weird things sometimes when the fan turns off
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    Had a similar problem on my b6, dealership told me it was the brake caliper braket, it was loose
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
