Results 1 to 7 of 7
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    need some help from the gurus (n75 related)
    well ive been having an overboost issue for a little time now..
    28psi is not good for tubros.
    so i took the car partially apart today and tested both wastegate hoses.. to my suprise they are perfectly fine.. ok.. now..
    there are 3 ports in the N75.. the boost ref port (from the compressor housing) , the wastegate port, and the other one that goes to the part of the spider hose (ambient pressure)..
    i put the vac tester on the ambient pressure side and it doesnt hold vac..
    now.. on this diagram.. if correct.. it shows that that ambient pressure side is its own... it doesnt share with the other 2.. so shouldnt it hold vac?
    or is that where the boost bleeds off is into the ambient port?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Dec 06 2007
    Calgary, AB, Canada
    Re: need some help from the gurus (n75 related)
    It definitely shouldn't hold vac. It's there so the ECU can sense the ambient pressure. It's not a sealed air line.
    Feb 28 2007
    chicagoland
    got ya.. well im in the process of just updating all the vac lines on the car.. in hopes of maybe there is a small small leak that went unnoticed..
    will update.
    Nogaro 01 s4
    620whp 93octane
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    I noticed the diagram above and it seems like the big nipple on the N75 valve connects to the little can at the center of the spider hose.... Currently I have removed the f hose and made a straight connection on the front part of the manifold... on the spider I capped the line that went to the F hose like this:
    Now my question is, can I disconnect the N75 from the spider hose and just cap the spider hose nipple... Will I create some kind of leak if I do this. I am starting to hate the spider and want to keep as many systems off of it as possible... Maybe Jerbel has some insight on this..
    Another question I had was related to that valve that connects to the y pipe... why do we need it? heck, with no more f hose and no n75 leaching off the spider hose why do I even need a spider hose back there? Can i Just put a filter on each crank case vent and call it a day and get rid of the homosexual spider for good?
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    i think you need to read up on what the pcv system really is. yes, some say you don't need it, and to a point they're right. but you can't cap off hoses and put filters on the crank case. it has to have a way of relieving pressure and vapors. the y pipe connection you can cap off, but the hose that leads to it, or where it originates should be lead to some sort of catch can so that it still does its job.
    Feb 22 2007
    Earth
    Quote Originally Posted by AAAA View Post
    ^^^^ what? the spider goes to the Y pipe because of emission regulations... the crankcase gasses will come out of a filter too wont they? Idk, maybe some more inmput on this...
    Established Member Two Rings alxjhn's Avatar
    Jun 14 2008
    2008 Audi A8L, 2011 Q7 TDI
    Pittsburgh
    do you have updated pics of the f-hose deleted in the engine bay???
