Results 1 to 13 of 13
    Mar 07 2007
    04 S4, blown 91 Mustang GT
    Indianapolis, IN
    Odd low oil level warning problem???
    Low oil light came on today. Pulled the dipstick and it was a bit low. Topped it off, started the car, let it sit for an hour, and rechecked dipstick (which reads good). Unfortunately the low oil warning light still comes on when I start the car. Its the yellow warning light, not the red low oil pressure light. It could just be a computer glitch, or the sensor may have decided to go bad. Either way its annoying. Just curious if anyone has seen this before.
    Thanks for your time.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: Odd low oil level warning problem???
    Are you sure you added enough? This thing holds a truck worth of oil...
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Registered Member Three Rings
    Jul 22 2008
    2006 S4 25th Anniv. Ed.
    Fed Way, WA
    The low oil light in my car seems to be picky... If the car is remotely close to being "low" on the stick, I get a light on. No worries though, I get the oil on the cheap, always keep a couple quarts in the storage compartment and check it every time I fuel up.
    http://i234.photobucket.com/albums/e...ProfileDay.jpg
    "I think I'm going to get metal legs."
    Senior Member Two Rings khyber's Avatar
    Nov 21 2007
    B6 S4
    Socal
    Generally when mine comes on, it needs close to two quarts, regardless of what the dipstick shows. The light will go off if I add one but I've noticed that generally two quarts is what it needs. How much did you put in?
    Mar 07 2007
    Indianapolis, IN
    I've put in 1 and 1/2. I don't want to overfill just to trn the light off, but the light and the inherrent beep everytime I put the car in gear is annoying. I'm due for an oil change anyway, so I might be doing that this weekend
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Quote Originally Posted by khyber View Post
    +1.. these cars are oil hungry..
    Dec 07 2006
    monroe, CT
    I've found the exact same as everyone else. I would say that I add a quart every 1500 miles...all highway. The light goes off when I add one quart but I typically put in 1 and a half.
    Remember this thing holds over 9 quarts and the light is programmed to go on when you're down by 1!!
    Mar 07 2007
    Indianapolis, IN
    Well . . . The light just went off by itself last night. I had not added any more oil since the quart and a half on Saturday. Go figure. Man these cars are tempermental sometimes!!!
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    since getting the car in April with 24,460 miles I've "topped off twice". The most recently last night on a 300 mile drive from eastern Long Island to Saratoga Springs. Both times I added 1 quart and it put me right back in the right range (a?/b? can't remember). Car goes in Tuesday for an oil change.
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Nov 12 2007
    Stamford, CT
    I've had the light come on twice (both on trips from CT to Long Island). I'm only at 19k miles.
    Both times I topped off and the light went off.
    Registered Member Two Rings
    Mar 29 2008
    Edmond, OK
    I had this same issue tonight. On the highway at about 75-80mph the light came on and so I slowed down and coasted to the next exit and hopped off. Being a newb I didn't want to take any chances. I pulled out the dipstick, it looked a tad low and when I started up the light was off. I took it easy driving home and when I got home it seemed much lower - like in the "C" range or less. I added two quarts and I'm back up to the "A" range. I looked at the owner's manual a little more closely and it says that "in hot weather during long-distance driving" that a lot of consumption can happen. I certainly have been doing this. It seems like this is a great lesson to me that this is a high-performance car and despite the rather large oil change intervals, that the oil levels should be checked more often. Just my two cents.
    Mar 07 2007
    Indianapolis, IN
    I would agree. I will now start checking the oil level every other week. While that may be overkill I would recommend that everyone does it at least once a month. Remember to let the car sit for at least a few hours before checking it. Ideally, let it sit overnight and check it before driving to work while the car is sitting on a level surface. That will allow almost all of the oil to drain back into the pan and give the oil time to cool. Remember that oil is a liquid and its volume will increase when its hot and hot oil may give you an inaccurate reading on the dipstick.
    Senior Member Two Rings Menlo S4's Avatar
    Aug 27 2008
    Bay Area
    Mine sucks-up oil, too. It used to stress me out, but over the years I've gotten used to it, and even expect it. I keep a coupla quarts and a funnel in the trunk.
    The manual says to add it 1/2 a quart at a time, but 1/2 a quart is never enough, so you find yourself under the hood once or twice before the oil light disappears for good. That's fine with me, though, since an early warning beats a too-late warning every time.
