Results 1 to 11 of 11
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    LED Tail Light Resistors - HOT
    Where do you people mount these hot little things?? I took a drive a 10 min. drive and they had already started to melt the plastic on the backside of the housing a little.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    Re: LED Tail Light Resistors - HOT
    umm why are they inside the housing??
    May 17 2007
    Quote Originally Posted by pyro View Post
    They aren't inside the hosuing, but there isn't much room between the housing and the body.
    -Ryan
    Maestro Tuned
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Are you using the correct resistor? I have mine heat shrink wrapped and then wrapped again in electrical tape. Overkill, sure... but no heat/melting issues.
    USP CLUB MEMBER #34
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Go here: CLICK, they have the kit so you don't overload the LED's. Eliminates the guess work. They also have chrome "stealth" bulbs for $3.29!!!
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Dec 06 2007
    mine never get hot.
    -Kirk
    BetaAlphaTau Member #58
    Mar 18 2007
    '05 A4
    Tampa, FL
    Quote Originally Posted by 04QuattroTurbo View Post
    i am certain he is talking about the LED tails, not replacement bulbs.
    May 17 2007
    Yes, I'm talking about the LED tails. What's the suggested load of the resistor?
    -Ryan
    Maestro Tuned
    Jun 15 2008
    Fairfield, CA
    It doesn't matter, that link has the replacement receptacle kits and the inline wiring to adapt our system to LEDS. I just mentioned the replacement bulbs for my Audi friends, just in case they are about to spend $30 on a set from Stealth Bulbs, with their fancy NASA coatings...LOL
    USP Member 110
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by Dolphin18T View Post
    Dude, surf the site, you will find the adaptor to equalize your circuit, so you don't heat or blow your LED's...
    Here Scroll down to the LED protectors...$1.99 each
    "Designed to help protect any led bulb from power and voltage surges
    Got a vehicle that eats leds??"
    USP Member 110
    May 17 2007
    Thanks!!
    -Ryan
    Maestro Tuned
