Results 1 to 13 of 13
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    when to the track yesterday
    Last month I went to the track with just a giac 93 flash and 710n's and ran a 13.9 13.7 .13.5 13.4 as the weather started to cool off. So yesterday I when back and I recently added a ssac downpipes w/ test pipes and catback and was hoping to get 13 flat if not high 12's. so heres my results =(
    1st run:
    r/t- .639
    60- 1.874
    330-5.718
    1/8-8.822
    mph-79.48
    1000-11.422
    1/4-13.6
    mph-101.75
    2nd run:
    r/t- 2.043
    60- 1.930
    1/8- 8.789
    mph-79.92
    1000-11.381
    1/4-13.592
    mph-103.06
    3rd run:
    r/t- 0.26
    60- 1.847
    1/8- 8.842
    mph-78.49
    1000-11.459
    1/4-13.719
    mph-101.33
    this def. isnt what a stage 2+ car should be running, i ran faster with just a chip last month, and i launched good and no missed shifts. Any ideas what could be making my times so high? and it was 70 degrees last night
    10 b8 s4 6MT sprint blue / black & silver
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: when to the track yesterday
    It's strange because your slowest 60' time was the fastest E.T. When are you shifting? I've had the best results shifting about 6000-6200. pretty consistent times though. your car should be capable of high 12s with your mod list and elevation. Not that i could get it there either but it shoud be possible. Boost leak?
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Nov 07 2007
    New York City
    thats what im thinking a boostleak somewhere, this car should be in the high 12's plus im a decent driver and i know how to launch
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    What are the specs on your 13.4 run?
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    If you dropped your .60ft a tenth or so and shifted quicker, i'd assume you can grab 2-3tenths back ... but, it should still be faster ... do you have the slip from the quick run with just the chip? Have you pressure tested?
    --Adam
    Have questions? E-mail me.
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    Your trap times are decently consistent with other stage 2 times. Thats the best guage of your power. To be in the high 12s your going to need to be trapping 106-107.
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Nov 07 2007
    New York City
    yes I have the time slip when I was just chipped 13.4 run but im at work right now so when I get home ill post it. but 13.7 is way to high for a stage 2+ car which leads to believe there is a boost leak some where or some type of problem
    Aug 06 2008
    Canadia
    mabey you got a bad tank of gas too, or you put shell gas in your car, that shell shit is kryptonite in any of my cars.
    Nov 07 2007
    New York City
    no bp and on the way to the englishtown i put in 20 of 93 sonoco
    Aug 18 2007
    Ohio
    Quote Originally Posted by MacDaddy View Post
    Im thinking shell is one of the better gasses out there. BP would be just about on the bottom of the list. I will only put Shell or Sunoco in my take unless im desperate.
    2002 TT Silver 225
    Nov 07 2007
    New York City
    i dont think it has anything to do with the gas..also marc logged my car for me yesterday and everything was how it should be requested boost met the actual boost but earlier today I did a second gear pull and it spiked at 17-18 and tapered down to 13-14 that cant be right why such a drop?
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Quote Originally Posted by VinNyS4 View Post
    K03's taper...
    Active Member Four Rings
    Dec 11 2006
    Boston
    They run out of breathe. Have you seen how tiny a K03/K04 is?
    Stage 3+ RS6's
