Results 1 to 3 of 3
Thread: Wheel bolts
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Wheel bolts
    Can I get wheel bolts that fit the S4 at the local Autozone, PepBoys, whatever? Or is this something I'll have to get aftermarket or from Audi?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Wheel bolts
    Quote Originally Posted by Talon Load View Post
    You could always try junkyards in your area. How many you looking for? I gots a sack full of bolts if you need some.
    Veteran Member Four Rings twinsnailsS4's Avatar
    Richard Henry Dana Jr.
    Re: Wheel bolts
    I have purchased OEM bolts from Autozone before and I know Shokan sells OEM ones for approx $20. However, the thing to be wary of is what wheels the bolts will be used for since the stock bolts do not work on all wheels. For instance, if you're pushing the wheel out further, the stockers may be too short. If you want aftermarket, check out the RAD bolts from PureMs--contact Mike as he is very knowledgeable and would be able to set you up with the proper lug seat and length you'll need.
    Current: B5 S4 Avant, F10 M5 (comp pkg), 14' Tundra (4x4), Lexus CT200h, BMW S1KRR
    Past: W212 E63, C6 A6 Avant, B5 and B7 S4 Sedans, FD RX7, a Civic Hybrid and 2 Beaters
