Originally Posted by
dougyfresh
1mm is a lot. That is an increase cross-sectional area between cylinders. A decrease in the heat transfer between cylinders and increase in strength to resist those large cylinder pressures.
Yes, 84.5mm bore IF you run naturally aspirated... Lower cylinder pressures.
But people talk about something they have never even tried and cant even prove that going 83.5mm bore is bad, they just say it because thats what they think even though they have zero experience with it or actual hard data to back it up. Plus it isn't like there have been any failures on any 2 liter builds just because they were running 83.5mm. If it was that bad I would have seen it fail at some point of running up to 32psi during the last 6 years. The funny part is that the one thing that has lasted the 6 years at 83.5mm bore is the block, oh and the pauter rods.
Heat transver between cylinders? You say that like one cylinder is going to be much colder then the one next to it, fact is that the heat is going to travel thru the the whole head and each of the cylinders are going to have nearly the same temp.
BTW I have seen plenty of people on the A4 forum post that they went 83mm so they could have room to bore again if they do end up with damage on the cylinder wall, so that means they plan on going 83.5mm even though some people on this thread say that its wrong to go that big. Maybe its not that they know its wrong, they just dont have the balls to do it period or do it the first time.
