    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Big problem!!! Suspension!?
    Well I went to install my new coilovers today. My Upper control arm bolt is seized and has been seized, so somehow I was able to put my springs on last fall, but I cant exactly remember what I did.
    I went to replace them today, and was able to get the old strut and spring off the front, but am unable to put it back on! I am able to push the suspension down, but I just cant pop the perch over, and its off like 3-5 millimeters. What can i do?!?!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Re: Big problem!!! Suspension!?
    Spring Compressor?
    Jun 04 2007
    Austin/DFW, TX
    The spring compressor just doesnt seem to allow the strut to push in enough, but I will give it a shot.
    My 5-Speed Swap DIY
    - B6 USP
    Aug 21 2008
    Minneapolis
    Quote Originally Posted by biketsai View Post
    BONGO!!!!!!
    Jun 04 2007
    Austin/DFW, TX
    The spring comrpessor didnt help THAT much, I got a little closer to putting the strut back on by turning the wheel, but i have like 3-4mm i cant clear the perch above the lower control arm.
    My 5-Speed Swap DIY
    - B6 USP
