Results 1 to 4 of 4
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    Idle goes blah blah blah
    2.8 30v
    i had an intake the only thing that has changed i cleaned the MAF with rubbing alchohol and installed the stock box again
    the MAF is my only suspect for the idle going from 200 rpm to 700 rpm everytime i come to a stop or put in the clutch
    anything else could cause this maybe bad timing and O2's are going out? im just wondring what to test i have a buddy with a new ethos scanner and ill T pin the leads and watch whats going on next time i drive to Sacramento
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    Dec 05 2007
    Re: Idle goes blah blah blah
    Should have used CFC MAF cleaner instead of alchohol. Log your MAF or find someone whom is willing to swap them out for a test to see if that is the culprit. If so, replace it.
    Nov 24 2005
    Bay Area CA
    anyone from the bay area ? ill VAG your car for codes and do that window mod if you come just pm me.
    pm for photoshoot
    Registered Member Two Rings MidwestA4's Avatar
    Oct 04 2007
    The Palm, Michigan
    i have the exact same problem.. it's for sure my MAF sensor. fcp on ebay sells some quality oem replacements for a good price.
    - 98.5 A4 Quattro
