Wtf so all over sudden the car won't go into reverse, 1st, 3rd or 5th. Basically the top gears on the shifter. When you put the shifter to any of those gears it pops right back into the neutral position. Its almost as if it won't fully go into the gear so it pops back out. When I try to hold the shifter in any of those gears and release the clutch it just grinds almost as if you're trying to shift without properly clutching.
Also it looks as if the shifter , when in neutral looks a bit forward, this could be just my perception by that's what it looks lke.
Edit: seems I can get it into any of the gears if I first press down on the shifter (you know the springy buffer) and press forward into that hear
Wtf mate?
