Results 1 to 7 of 7
    Registered Member Two Rings
    Aug 13 2008
    New England
    B7 S4 Exhaust & Chip
    Well,
    despite my plans of getting a used RS4, I am looking at a really nice S4 from my long time mechanic. I was wondering what are some good, loud, exhaust upgrade options for the later b7s? Any suggestions?
    Also, are there any chipping options for increased performance for the 4.2 V8? I don't know much about chipping, aside from what my mechanic has said, but I do know more people are chipping the 2.7t B6>'s, apparently it's easier? Is it worth chipping it?
    Thanks,
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Re: B7 S4 Exhaust & Chip
    haha exhaust post. Do a search. There are tons of threads dedicated to each and every exhaust option available for our cars. The more common ones tend to be AWE, Milltek, Fast Intentions, LaBree, and various others.
    You can chip our cars, but it doesn't do nearly as much for them as it does for the 2.7tt, or any forced induction car for that matter.
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Sep 16 2008
    B6 S4 Avant Nogaro 6-speed MT
    Normal, IL
    Hey, I searched around and this thread was right on topic for what I was wondering. Anybody know (or can you point me to info) exactly how much power a downpipe/catback exhaust along with a chip will make on the 4.2L S4? I'm thinking about doing this, but am not sure if it's worth it.
    I've been told by one aftermarket company that the HP will be bumped from stock 340 up to approximately 390. Does that sound right?? If so I think the money spent is "worth it", but I wanted to verify if that statement is accurate....
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    Quote Originally Posted by NewEnglandRS View Post
    Well,
    Thanks,
    For info regarding downpipe/chipping, look at my answer below. When it comes to choosing an aftermarket exhaust, I would recommend Neupseed's 70mm catback. The sound is intoxicating and it is superior in quality. A perfect mix of loud w/o drone.
    Quote Originally Posted by Captain Insano View Post
    Unfortunately, there is no way that this info is accurate, nor would it be safe if it was true. The S4's 4.2L is running an incredibly high compression ratio from the dealer, and chipping it will only yield 4 to 5 hp and a slight bit more torque. Really, a chip just smooths our power delivery, eliminating the slight power deficient spots in the rev range.
    Adding a downpipe+catback will yield around 15 to 20 hp.
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
    Sep 16 2008
    Normal, IL
    That is unfortunate. So spend thousands of dollars and gain 20 at the crank?? Just seems really, really low for the money.
    What is the compression ratio of the Audi 4.2L 8-cyl by the way?
    Registered Member Two Rings coldfusion9xx's Avatar
    Sep 11 2008
    05 Audi S4, 07 Kawi ZX10R, 05 Fusion 900
    Lowell
    4,163 cc 4.2 liters V 8 front engine with 84.5 mm bore, 92.8 mm stroke, 11 compression ratio, double overhead cam, variable valve timing/camshaft and five valves per cylinder with 340 HP SAE @ 7,000 rpm; 302 ft lb , 409 Nm @ 3,500 rpm
    Best advice...throw a cat back system on there and call it a day...milltek sport is what I have...sounds amazing and you can really hear the engine and feel a little more response in acceleration
    If you want to get 390+ horse...be ready to dump some big money into it or...just start saving for an RS4!
    Veteran Member Three Rings norsecarnut's Avatar
    Sep 15 2008
    2 Land Rovers, BMW E61 mt6
    As I posted on another thread - what about this? :
    http://www.powerchipgroup.com/produc...2008&make=Audi
    gain claimed is higher than those above. APR downpipes/full system looks better than cat-back to me.
    Stassis center diff is appealing too.
    2008 S4 Avant mt6 Dolphin - APR Full exhaust / Escort 9500ci-stealth install / backup camera / aux-in & ipod & cd / 35% ceramic / 2" hitch class 2 / Nokian WRG2 / HID fog / Stasis high-bias center diff
    AKA: jwest
