Results 1 to 6 of 6
    Apr 07 2008
    Little Tikes Hummer for my son
    Montréal
    Toc Toc sound in vents
    Hello all,
    Maybe the sound I have is normal, I tried to search but did not find mutch with toc toc.
    I noticed a sound in the vents. It is hard to discribe the sound, it is a bit like if a gear would be at the end it can go and is being forced and skipes Toc...
    Normal???
    Thanks
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    Re: Toc Toc sound in vents
    I have the same exact thing. I know exactly what your talking about..but I too have no idea. any help from anyone would help great. My ac runs fine and the car is in good shape 03' with 43K. I will even hear the noises after I have just turned my car off.
    Nov 12 2007
    Grand Junction, CO
    I think its normal. I get it too.
    Established Member Two Rings b929's Avatar
    Jun 15 2007
    i get tat also once in a while, then it'll slowly go away
    Senior Member Two Rings rings65's Avatar
    Jan 14 2008
    '06 A4 S-Line
    Wheaton/Winfield, IL
    Most likely bad temp flap motors. I had the same thing, and when I took it in they replaced the temp flap and recirculation motors. Problem solved.
    Established Member Two Rings sacul33's Avatar
    Mar 06 2008
    2008 Audi A4 2.0T
    Woodstock, GA
    I had the same thing, then I asked the dealer. They said it is just the vents adjusting to make sure nothing is wrong within them. It is normal. It is only supposed to happen when the car starts.
