Results 1 to 7 of 7
    Mar 17 2008
    Couple questions ;)
    Hey
    - Whats the best cable i can buy to connect my ipod touch to non-bose symphony in a4 2005.
    - Why my rear brake pads produce lots more brake dust then front ?
    Front and rear are oem brake pads.
    Also what can i do with my drivers seat i see it starts to crack a little. :(
    Thanks
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Re: Couple questions ;)
    The rear brakes a undersized so they are over worked which is why the produce so much dust. You will more than likely change your rear brakes twice as much as the fronts. I went through two rear pads before my fronts needed to be changed once.
    As for your seat, do you have leather or leatherette? With leather you can try a liquid leather repair kit, but the best solution is reupholster or buy a new seat.
    Mar 17 2008
    Where can i buy recaro seats ? Lets say from s4 ? would they fit ?
    Thanks
    Buncha motorcycles
    Memphis, TN
    junkyard...
    get some hawk HPS or carbotec bobcats for the rear pads.... i hated how badly my rears dusted....
    APR Stage 2/AWE Intake
    Mar 17 2008
    I will do that next time i buy pads.
    What about itouch connection ?
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Answer to your first question is here.
    Answer to your second question is here.
    Answer to your third question is here.
    -Darrick
    Mar 17 2008
    Sorry for not searching but when i posted this question i was about to leave to work.
    Anyways thanks :P
    PS- Didnt find alot about Itouch in b6 section.
