Who exactly do you get the timing belt on?
Tooth for tooth is not exactly the same.. in other words the old belt was marked at the drivers, passengers side and crank. (two marks at each location). I made the same marks on the new belt... I can make the passenger side and the drivers side meet the same marks, however from the drivers side to the crank is soo tight I think it was 2 teeth off from hitting the mark but there is a ton of slack from crank to passenger side. ---Make sense... ?
Through all the tech articles no one mentions the marks on the timing belt..
so how exact do you get it on?
Oh btw I have the cam lock on and the crank has not moved at all...
