Results 1 to 8 of 8
Thread: Boost issue
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Boost issue
    anyone ever have this problem before
    my car will spike to 22 and then hold at like 19-20
    but before redline itll start creepin up to 25psi and it just keeps goin.
    i put an MBC on it last night and only ran 14psi but it held it fine.
    now.. do you think an N75 valve is the culprit.
    my car has a MINOR MINOR.. idle fluxuation.. and when i put the MBC on it went away.
    so i am thinking my N75 may be bad?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Re: Boost issue
    did you run only mbc last night, or parallel to the n75?
    ThorTechnik.com
    Feb 28 2007
    chicagoland
    Re: Boost issue
    mbc only
    Nogaro 01 s4
    620whp 93octane
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Re: Boost issue
    my car would spike to 25 and taper to 23 on my n75, but that was with my old shitty VAST tune. i took out the n75 and ran standalone MBC on that same tune and it ran great. My MBC tapers a bit, but i know thats the MBC, need a better one.
    to answer your question, your n75 is the culprit. wether its the tune or the MBC. you can figure out which one by logging it.
    Feb 28 2007
    chicagoland
    Re: Boost issue
    i dont have the capability to log anything.
    and its not spiking to 25...
    after the spike and the taper it jumps to 25 and holds before redline.
    Nogaro 01 s4
    620whp 93octane
    Sep 27 2007
    hate on me <3
    Re: Boost issue
    i understand that, just saying my situation.
    i believe its channel 115 on a vagcom, you dont have the cable and a laptop? if not post up in the regional section im sure someone will be happy to help you.
    Feb 28 2007
    chicagoland
    Re: Boost issue
    yea ill see what i can come up with. and post back
    Nogaro 01 s4
    620whp 93octane
    Dec 06 2007
    Calgary, AB, Canada
    Re: Boost issue
    That's called boost creep. It happens mostly in the higher gears. The N75 is likely faulty, either that or the tune requests too much boost in the higher rpms.
