And when I put my arm down there to try and get it off with an adjustable wrench, my hand came back with oil on it (clean fresh oil). Could that be a leak in the valve cover gasket? I replaced the exhaust valves couple months ago, so I don't think that is it. I am not too knowledgable about cars, but are there maybe some missing bolts on the valve cover (so what it seems, or maybe they are just there because). I took pictures of the valve cover to show if you may think there are any bolts missing.
2 questions:
1)Can I use PB Blaster on the 02 sensor to get it out without messing up the sensor?
2)Where do you think the oil leak is coming from? valve cover? If so, I found the DIY and it seems a rather straight foward procedure. I just do not want to spend money on a wrong diagnosis.
Edit: I just went to Autozone and the guy said that the PB Blaster should be no issue with the sensor. He also showed me (rented) an 02 sensor fitting used with a ratchet to get the sensor off
Edit 2: Those sensors won't budge for nothing. Used the PB blaster (more than 1/4 of can) and nothing. What should I do? I am thinking just go to a shop and see if they will take it off for me. But the alteration of what I want them to do afterwards is highly unethical in the automotive business world, as I will then proceed to request them to place the foulers on.
*yeah, I know the engine and bay needs a good cleaning. I will do that eventually. if it is the valve cover, I will also paint it black while it is off
