Results 1 to 21 of 21
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Stained window problem
    I could not find anything searching, there was something about it a while ago but it did not pop up...I have these little spots all over my windows, every window. They are definitely on the outside of the car.My windshield is covered with it and when it rains you cant see anything. I have tried everything to get it off, goo gone, paint thinner, every other house hold item i could think of, and nothing...Someone said there was a product that would get rid of it, i was wondering if anyone knew what it was...
    Thanks
    Miles
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Re: Stained window problem
    2 different solutions, you can use whichever you like.
    1. 0000 grit steel wool and window cleaner (your choice). Spray a liberal amount of the cleaner on the window, and work the steel wool up and down the window. Will take the spots right off.
    2. Clay bar. Usually works, but takes a bit more elbow grease to get stubborn spots off. Same principal as above for use. Spray plenty of the lubricant provided with the clay bar on the window, work the spots off.
    After either one, wax your windows with your favorite wax. Yep, I said wax your windows. Work better and last longer than Rain-X, and without the hassle of trying to get your windows streak free.
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Feb 25 2008
    Cape May, NJ
    i used steel wool, nothing
    used the clay bar, nothing...nice waste of 20 bucks for all of that
    Did find something that works and works fast...its called rust stain remover....put it on and within seconds the spots came right up....wonderful product, it does say dont use on windows but i used it real quick then washed the window with soap n water...Came out great....
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    May 14 2008
    W-S, NC
    Interesting. I've used steel wool and clay bar, both did wonders for me. There's also a guy around that sells a products specifically for water spots on windows. It's almost a paste, works wonders. Can't remember the name off the top of my head, I'll post it up when I get home.
    Feb 25 2008
    Cape May, NJ
    ok so i used it on the windshield...It cleaned the whole thing but now where the windshield wipers hit on the windshield, theres a fog on it, the rest of the windshield is very clean except where it matters most. i tried vinegar to get the fog off but did not work...Now i need something that will clean that fog off..Anyone have any ideas??
    I think it may be time for a new windshield.
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Veteran Member Four Rings Undisputed's Avatar
    Jun 28 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    That's probably why it said not to use it on glass.
    A new windshield may not be a bad idea at this point. With all the stuff that has been on your windshield by now I'm surprised it hasn't melted away. lol.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Feb 25 2008
    Cape May, NJ
    i did the back window and its flawless, its just were the wipers run on the windshield..
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    you can see thick individual lines on the windshield from the wipers.
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    May 14 2008
    W-S, NC
    The glass was probably already etched from the wipers, and when you got the rust remover in them, the acid etched it even more and fogged it. You could try polishing it, but other than that, you're SOL.
    Feb 25 2008
    Cape May, NJ
    what kind of polish are u talking about. i am def interested, yeh it looks like they were etched bad before i got the car and audi detailed the whole car and prolly polished the windshield so it wouldnt be noticable...def no bueno...on a side note, every other window looks amazing....
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    May 14 2008
    W-S, NC
    You can probably find some kind of glass polish at a hardware store, or even an auto parts store. You could try using some car polish (non abrasive), but it might just leave residue behind in the etching. Or...you might just try washing the car with soapy water, that might help?
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    really fine steel wool and simple green then windex then wax
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    Jun 08 2007
    Orlando, Fl
    This stuff will do the trick- http://www.detailersdomain.com/index...ROD&ProdID=131
    Also if you have a rotary you can polish your window with a buffing compound to remove scratches or etch marks from windshield wipers.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Feb 25 2008
    Cape May, NJ
    thanks for the help guys, i went to an autobody shop and let them look at it, they said they used the same stuff i did to get the real hard crap off and sometimes when people dont change wiper blades often (previous owner did not) this will happen. so i am going to try the polish it to see if it works...There are no cracks or anything, i ran my hand on the windshield with my fingernail and did not feel any cracks at all..So i think it just needs a good polish. thanks again
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 25 2008
    Cape May, NJ
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I have the same streaks on my windshield....not to noticable from the drivers seat so it doesnt bother me...but it fairly visible from the passengers seat.
    Definetly interested as to what will clean/remove the streaks
    -Sami-
    Aug 26 2005
    A polishing compound using an abrasive at least as hard as the glass itself, is required to polish out the wiper tracking marks. A random orbital sander setup with a cushioned pad, to apply the polish will be a lot easier and faster. Using a coating over the existing wiper scoring, may help a bit for a short time, but can cause problems seeing clearly when wet or when the film becomes contaminated.
    The proper fix is either polishing the glass with a specialty glass polish, or replace the windshield.
    Feb 25 2008
    Cape May, NJ
    What type of glass polish are u talking about, the einszett glas polish seems to be the ticket, but im not sure yet, never had this problem before with windows...damn hard water spots...
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
    Aug 26 2005
    Quote Originally Posted by OneBadAudi View Post
    A Cerium Oxide polishing compound made for glass polishing is recommended.
    http://www.eastwoodco.com/shopping/s...olishing_glass
    May 14 2008
    W-S, NC
    Good to see dianosticator offering up help again. I have the exact same streaks on my windshield, plus I have a nice crack in the lower passenger side (which I didn't notice until AFTER I bought the car). I think I may just break down and get a new windshield...
    Feb 25 2008
    Cape May, NJ
    yeh i will def try this first to save me a couple hundred bucks....THanks for the help diagnosticator
    APR R1 DV
    K&N Air Filter
    5% tint
    Lip Spoiler
