Results 1 to 21 of 21
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Need Torque Specs!
    Hello there, quite frankly I don't feel like searching around and trying to find all of them so if you can be kind enough to bring them here to this post I would greatly appreciate it and it may help someone in the future the were to search
    Head Bolts
    Oil Pump (think this is like 9 ft/lbs)
    Cam Caps
    Oil Pan (think this is 84 in/lb or 7 ft/lbs)
    And I dont have the torque specs for my rods which have ARP 2000 rod bolts. So anyone know the torque specs for those rod bolts? Pretty sure they are in like all rods just about.
    Thank you and have a good day.
    O yeah, Im tearing the car apart tomorrow and over the weekend.
    Going in are:
    Pauter rods
    AEB Forged 20mm Pistons
    New Rings
    ACL Calico coated rod bearings
    AEB head
    Schrick 252/260 cams
    New oil pump
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Need Torque Specs!
    Are leaving the block in the car or pulling the whole engine?
    -Sami-
    Apr 24 2005
    E55 AMG, CTS-V
    in car
    ~David~
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    cam caps are 10n-m
    oil pump is 'nice and tight'
    head. I forget but john or Jordan knows
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    You'll have to convert these.
    Head bolts-2 stage 40Nm+180 degrees, 2 90s are ok
    Cam caps-10Nm
    Oil Pump-16Nm
    Oil Pan-7mm 15Nm, 10mm 40Nm
    Rods- 30Nm+90 degrees (These are factory bolts, so I'd check)
    Let me know if you need others
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by dirtybrd View Post
    Cam caps-10Nm
    Oil Pump-16Nm
    50-55 ft/lbs for the arp rod bolts...... well forget it. I will quote another post with all that info.
    Quote Originally Posted by pete@integrated View Post
    OK, it sounds like it is time to straighten a few things out regarding rod bolts.
    This all applies to the ARP 2000 bolts- NOT the factory bolts!
    Under normal usuage, assuming they are not overtorqued in the first place, they are operating within the elastic portion of their stress strain curve so they ARE reusable.
    The only way to really determine 100% if they are acceptable to reuse is to measure them brand new, record those values, and compare to them when you go to reuse them. This will tell you if an over rev or some other event has damaged them in use.
    The proper torque is 50 to 55 ft-lbs, using the ARP Lube. DO NOT follow the factory torque procedures, I have never tried to see what torque that equates to, but in any case, the proper torque is 50 to 55 ft-lbs with the ARP Lube. You can also do them directly off of stretch if you have a gauge, .006"- but most people don't have a rod bolt stretch gauge.
    They should also be torqued (to about 50) and broken loose, twice, and then torqued to the final torque- this burnishes the threads and makes sure everything is worn in so that the torque readings give an accurate preload on the joint.
    I think that should set straight most of the stuff on this thread regarding bolt torque. I tried to keep it pretty brief.
    Sorry about the not price matching- purems doesn't list what brand any of their products are, and the day you called I tried to call them and they were already closed for the day. After that it just sort of got lost in the cloud of stuff to do before we left for vacation.
    Mar 21 2006
    Lakeland, FL.
    That's why I told him to double check.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    Thanks, I don't need to convert, I will just use the Nm
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    Werd!
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    Need more specs please.
    Crank bearing cap bolts
    Flywheel bolts
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    I'll get them in the morning.
    I'm back bitches!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    DMFW: 22.5mm OEM bolts is 60Nm plus 90deg
    pressure plate bolts are 22Nm with loctite
    -Doug
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    65Nm plus 90 degree further for crankshaft bearing cap TQ
    60Nm Plus 180 Degrees for flywheel to crank shaft
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Oct 29 2005
    10speed
    San Francisco, CA
    this needs to be in the sticky... very useful info
    - Clint
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    How many miles on the motor? isn't honing required?
    Apr 24 2005
    E55 AMG, CTS-V
    The motor IS being honed as well as more clearance being put in the cylinders to allow the Forged pistons since they expand more than cast. Needed an extra roughly .020 shaved to have .035 clearance between piston and wall and 80,000 miles are on the engine.
    ~David~
    CTS-V 9.6@148
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by A4 TSCHUSS View Post
    BobQ gave me .030 with my Wisecos, might wanna stay on the safe side
    - Clint
    Apr 24 2005
    E55 AMG, CTS-V
    The bentley says .035 for the AEB piston to wall clearance. Here ya go click here
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    AEB pistons are a different forged aluminum then aftermarket ones, i assume to keep the noise on cold starts down.
    I'm back bitches!
    May 24 2007
    Southern California
    this is definitely a big help.
    Kyle
    2.0L Revo GTRS Eliminator
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    No, thats .003" not 0.30" lol... The stock clearances are .0015" according to the Bentley
    And David, I would shoot for .002" MINIMUM, I repeat, MINIMUM for aftermarket forged pistons
