Results 1 to 6 of 6
    Sep 25 2007
    Nashville, TN
    Timing belt problem 3.0
    I just change my tb and i got the following codes.
    P0025--"B" Camshaft Position - Timing Over-Retarded
    P0015--"B" Camshaft Position - Timing Over-Retarded
    P0113--Intake Air Temperature Sensor 1 Circuit High
    P0102--Mass or Volume Air Flow Circuit Low Input
    At first the car was idling at 1000 and running like crap. it was sluggish with the rpms
    After i erased the codes, the idle is fine. and it works perfect.
    I figured I would get advice from you because i have a 3.0 A6 and most people dont so i know there are alot of 3.0 A4s. Any help would be awesome.
    Feb 17 2005
    Sarasota, FL
    Re: Timing belt problem 3.0
    Its possible that you didnt have enough oil pressure to advance (or retard) the cams at first startup, the VVT is ran by oil pressure FYI. If you cleared the codes and they have not returned and the car is running correctly, I would just wait to make sure nothing returns. If the codes did come back, it is timed incorrectly. I havent personally done a 3.0, but on the 1.8, if you have everything inline when you put the tensioner in, the timing will not line up correctly. You have to start back a partial tooth on the head for the tensioner to pull it into correct timing
    Sep 25 2007
    Nashville, TN
    so i drove it all tonight and no light came back. Does that mean im good? the car is driving different but i think it might just be in my mind b/c i saw the CEL. It is a hell of alot smoother though.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I agree with Shawn. (post #2)
    What do you mean by 'driving dfferently'? Is the engine running smooth? Is idle smooth?
    -Doug
    Sep 25 2007
    Nashville, TN
    yeah it is. according to my dad, the car would be running very rough if the timing was off. I dont know if this is the case.
    Sep 25 2007
    Nashville, TN
    anyone else have any advice? I ask because im going to school tom. and i want to make sure my car is okay before i drive it 400 miles.
