Results 1 to 13 of 13
    Senior Member Two Rings BGEDWN's Avatar
    Mar 28 2007
    B7 S4 MT6
    Bronx, NYC
    How to remove ashtray door?
    The door only opens half way, I think a coin fell behind and is blocking it. Anyone had this happen?
    '06 B7 MT6
    Sprint Blue / Silver - RNS-E / Bose - Premium Pkg
    Corsa Catback / ECS Snub / RS4 Pedals / Hoen Xenonmatch / K&N
    In, Out and Around...
    Re: How to remove ashtray door?
    assuming youre referring to the front one... in the half way open position squeeze the top part of the trim and the lower portion of the ashtray door, and pull the top portion (trim portion) towards you with your fingers.
    Mar 28 2007
    B7 S4 MT6
    Bronx, NYC
    Yes, the front ashtray in front of the shifter. I tried what you said and the trim wouldn't separate. Is that a way to remove the entire door or just the trim?
    '06 B7 MT6
    that is just to remove the trim... you could remove the whole ash tray by removing the shift surround and then unscrewing and pulling it out... but its easiest just to pull out the trim...
    maybe this helps:
    http://www.carboncopydesigns.com/Ins...on.aspx?type=3
    if youre still having issues, we could meet up im in nyc... i could get the trim off in a few seconds, or the ashtray out in just a few minutes.
    Dec 28 2007
    2004 B6S4 6MT Nogaro
    Hoboken, NJ
    I had a hell of a time getting my ashtray trim off (I'm getting my trim wrapped in CF)...
    Cheers,
    -Kurt
    2004 B6S4 4.2L Sedan (built 03/04, bought 09/07) | 6MT | Nogaro Blue w/ Black Leather w/ Blue Alcantara | CF Trim | 20% 3M Tint | AWE Non-Res Catback | 18" BBS RX | SportContact 2 (summer) | Blizzak LM25s (winter)
    2000 C5A6 4.2L Sedan (bought 07/05, retired 09/07) | Tiptronic | Ming Blue w/ Tan Leather | Wood Trim | Goodyear Eagle F1 GS-D3 (summer) | Blizzak LM22s (winter)
    Mar 28 2007
    B7 S4 MT6
    Bronx, NYC
    I removed the shifter surround and managed to pull the ashtray assembly out somewhat. I couldn't get it out past a certain point and wasn't able to get to whatever is blocking the door from opening all the way. Any ideas on what else I can do?
    '06 B7 MT6
    Veteran Member Four Rings streamline's Avatar
    Sep 03 2004
    Pittsburgh, PA
    if pull the radio and climate controls out it will slide right out
    Ryan
    2009 A4 Avant: Brilliant Black
    2002 Allroad 2.7T: Atlas Grey
    Mar 28 2007
    B7 S4 MT6
    Bronx, NYC
    Quote Originally Posted by streamline View Post
    Steps?
    '06 B7 MT6
    radio keys in the slots of the radio... pull out radio, then iirc two bolts hold in the hvac unit then pull out then slide the ashtray up and out.
    Sep 03 2004
    Pittsburgh, PA
    actually there arent any screws for the hvac, the radio hold it in just slide it out
    Ryan
    Mar 28 2007
    B7 S4 MT6
    Bronx, NYC
    I have RNS-E. Are above for Symphony or RNS-E?
    '06 B7 MT6
    Sep 03 2004
    Pittsburgh, PA
    it doesnt matter
    Ryan
    youre right, i just did mine today... i was confusing the two 8mm screws that were holding in the ash tray, the hvac just pushed right out.
