Results 1 to 2 of 2
    Veteran Member Three Rings RAyala2.7T's Avatar
    Mar 08 2005
    Austin, TX
    Bilstein struts/ vogtland springs(its no n00b question)
    I've looked at the suspension FAQ. I've searched already to no avail. I've emailed pure ms and already received an answer.
    I've seen plenty of koni/vogtland setups and that is the spring/strut combo I'm going for. But for the price of the konis I might as well just get coilovers again. Has anyone used vogtland springs with bilstein struts? If so, whats your input on them? Pure MS told me while the ride quality won't be as nice as the Konis, it comes down to personal preference. So, if you're running this spring/strut combo please let me know.
    Rob - 2000 Audi S4 VAST Stage III
    Oct 31 2005
    Ashburn
    Re: Bilstein struts/ vogtland springs(its no n00b question)
    Havent had any experience but if you look at most of the people who have and H&R Bilstein combo there are rebuilding or replacing shocks often.
    Personally if i had the money i would get the Koni's , plus there adjustable right? also check ebay, i found a set of koni's for 470 all 4 corners which is about what you would spend on some bilsteins.
    either way i wanted koni's but settled for a used set of H&R Bilsteins at a good price.
    - Instagram: @Sinister_rs5-
