Results 1 to 7 of 7
    Dec 14 2006
    Halifax, NS, Canada
    Has anyone had this happen
    I installed new control arms a while ago and it sat. The car didn't make any noise from the suspension the first couple 100km but searing was really heavy. It has gotten lighter and now it clunking, has anyone else had to retorque all the suspension bolts after a bit of driving?
    Also what vac do people usually have at idle I have around -24psi and have a boost leak seems lower then it was previously...
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Re: Has anyone had this happen
    Did you torque the bolts at ride height (jack up the hub)?
    Dec 14 2006
    Halifax, NS, Canada
    initially yes... dono seems odd oh well just one of those things.
    NOW DEAD :(
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Normal vacuum @ idle is 18-21in Hg. (rated in inches mercury, not negative psi). Under hard decel/engine braking you should see higher than 22in Hg. Basically the higher the vacuum the better. If you really are pullin 24in Hg @ idle, I don't think I'd trust your gauge. Is it fluxuating @ idle or anything weird?
    It wouldn't be a bad idea to recheck the torque, but to actually need to, I'm not sure. I haven't had to. Is the noise coming from the same arm/joint you replaced?
    Dec 14 2006
    Halifax, NS, Canada
    Its not the joint I'm pritty sure its the joints. I installed the control arms and it sat for 6 months so i think it needed driving and re torque, maybe I didn't load the suspension enough when I did it. I am doing boxster brakes and s4 rears on monday so ill just torque them then.
    Ill send a video of idle vacuum. I have a new exhaust and bov on there, but i seem to remember the vacuum was 20 on the boost gauge before.
    NOW DEAD :(
    Jun 25 2007
    Phoenix
    did you pre-load the bushings/joints?
    Dec 14 2006
    Halifax, NS, Canada
    Quote Originally Posted by im sofa king View Post
    yes initially I used a tranny jack as it was on a hoist. I am thinking might not have loaded it enough. I am using a floor jack to re torque them.
    NOW DEAD :(
