I have been stage 3 for a little over a month and having a problem. Initially the speedometer was bouncing around and the gas gauge as well. I replaced the VSS, still the same issues followed. I have also search for damaged wires and have found not one. Recently the speedo is either working or dead, no longer bouncing around. While it's dead the gas gauge will go up and down and the car throttle cuts at around 5,000 rpm. Anyone ever experience this type of issue? Just wondering if it may still be associated to the VSS itself or possibly something with the ECU. Also CEL shows Vehicle Speed Sensor, implausible signal. Any help is greatly appreciated. Thanks in advance.
