Results 1 to 7 of 7
    Established Member Two Rings stilldubbin203's Avatar
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    Need help from the Tapp tuned guys!!!!!!
    ok so to make a long story short i think my tapp tune has shit the bed. Im running the 93 oct file on my gt2871r eliminitaor setup with the ford lightning maf, and siemens 630cc's. I keep getting different codes. First i got the code for the internal control ram error aka. dead ecu, then i got a 17967 throttle body adaption code saying theres a fault in the basic settings so it wont adapt, and i keep getting a random coolant temp sensor signal too high code. Along with those now when im idling and fully hit the gas there is a delay, then the car starts misfiring and backfiring, and also the idle goes to about 1400 rpm's and wont come down. Ive recirculated my BOV, put in new plugs, tried to adapt my throttle body 150 f'en times, checked for boost leaks, and anything else i could think of. I finally put my ko4 ecu back in just to see what would happen and the car started up, idled perfect, had perfect throttle response, the throttle body adapted immediately, and everything was good. I just dont know what else to try. Does anyone think there could possibly be a fault in the file? I need help! Please!
    SoCo Dubs Bitch!
    99.5 A4 1.8TQM - / GT2871r elim. \ / Tapp Tuned \ /ATP High Flow Turbo Manifold \ / FMIC \ / siemens 630cc \ ATP Hard TIP \ Coolingmist/Labonte Meth injection \ Fprd Lightning Maf \ / stasis coilovers \ /StopTech Rotors + Hawk Pads \ / tyrolsport afpr \ / borla catback \ / DIY intake \ / clear corner mod \ / 8000k hid's \ / vdo center vent boost gauge \ / s4 bumper with shaved center grills \ / aem wideband \ / 18" RPM 505 Wheels \ / Forge 007\ /Turbo XS MBC \
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    Re: Need help from the Tapp tuned guys!!!!!!
    hhhmmm this is a good one, I havent heard this one b4, you defenitly need to contact Chris on this one he's very nice and will help you
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    ahhh this sucks
    SoCo Dubs Bitch!
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    bump
    SoCo Dubs Bitch!
    Feb 27 2005
    North Wales, PA
    its your intake set up. trust me. I fixed mine and all the codes went away. The check sum error code happens when the ford lightning maf and the ecu are fighting.
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    I just don't understand why the throttle body won't adapt and I'm getting a coolant temp sensor code. Like I said, when I swapped the ko4 ecu in everything was perfect. Could it be that my Maf Is connected directly to my filter?
    SoCo Dubs Bitch!
    Feb 27 2005
    North Wales, PA
    its possible. believe me. I had the same codes except for the coolant temp sensor.
    it could be maf disturbance or a intake leak.
