Results 1 to 28 of 28
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    Question Spark Plugs/Coilpack question (Bosch F6DTC)
    ok, so I am getting misfires under boost (BAT setup) and I was told it was probably just the tune b/c its not quite finished. but I decided to check the plugs anyways, Im running the Bosch F6DTC's. I cleaned them and went to put them back in but notice that the coilpack doesnt really "click" onto the top of the plug, is that normal? Its been so long since I ran BKR6E's I dont remember what they felt like, but is the coilpack suppoed to "snap" onto the plug or does it just sit there, it almost feels like the Bosch's arent long enough, though I doubt that. And I threw on a new coilpack (my spare) just to check and it felt the same.
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Re: Spark Plugs/Coilpack question (Bosch F6DTC)
    you got your setup running already? am i missing a thread?
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Dec 14 2006
    Halifax, NS, Canada
    wouldn't you want Bosch F5DTC?
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Feb 09 2007
    00 S4
    MA
    he got his setup up and going awhile ago...but hes too cool to post pics or make a thread about it...it's nuts though
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Jan 06 2007
    NH
    Quote Originally Posted by Squarrl View Post
    I was told to get these by Mike, I trust him...
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    I would say it's coilpacks. B/c I was having the exact same problem. I only had one bad coilpack butbi went ahead and replaced all 4. It was only 100 bucks for them.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Jan 06 2007
    NH
    I have the hitachi's for the 2000 I think they are a little more, but maybe I'll find a good deal, I checked VAG-COM and it said I have multiple random cylinder misfires and individual misfires also...
    Dec 14 2006
    Halifax, NS, Canada
    Quote Originally Posted by Euro-Tuner View Post
    no doubt they are also the plugs I use... just for the BT applications would have thought you wanted colder plugs.
    NOW DEAD :(
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Try Bosch F7LTCR,you can find them easier and they are almost same with F6DTC but 1 step colder.
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    i ran f5's, they're a very cold plug. went back to the f6dtc and never looked back. if I ever go back to and bosch 5 plug, it'll have to be in a iridium/platinum setup.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    What is your BAT setup? If it's up and running you really should try an post some pictures and info., reciprocation for those who offered info and help etc....:)
    Sep 24 2005
    always in design
    Those are not the plug you should be running at all!
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    FR5DTC
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 14 2006
    Halifax, NS, Canada
    Quote Originally Posted by bassed View Post
    I shouldn't use F6DTC?
    NOW DEAD :(
    Sep 17 2005
    Dublin
    Forget bkr6e. Youd want bkr7e w/ a bat. Misfiring only under load can be a sign of a cracked spark plug inuslator. Check them for very small hairline cracks. That'll do it. Especially if you're running too hot of a plug.
    2000 A4 1.8T
    1997 A4 1.8TQM
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    F6DTC is 1 step colder then stock
    F5DTC/FR5DTC is 2 step colder then stock
    I run F6DTC pushing 32psi on my 8.5:1 CR setup. The BAT setups can use a little hotter plug since the turbos move air at a much cooler temp then a BT and K03/K04 setups. Now if he is running very low boost at this point he might want to run a stock heat range plug since the IAT's are going to be really low and his cylinder temps are also going to be lower, then when he goes in to have it tuned for high boost he can throw the F6DTC plugs back in.
    Jan 06 2007
    NH
    I agree, I probably should/will I just dont like flaunting my shit unless its in person and even at that I'll only do it with enthusiasts, not my local yokals.
    Mike, I am running at about 26lbs right now so I think my plugs should be fine, I cleaned them up and it runs much smoother, but after a day of driving I am still getting cylinder 1, 2, 3, & 4 misfires and multiple random misfires, when the tune gets to the next step I will post back and let everyone know what the problem was, and if anyone has questions about my setup feel free to PM me, I'll be more than happy to help if you get stuck as would many people here.
    Jul 07 2004
    socal
    26psi on pump, race or pump with W/M injection?
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    Does the resistor part make a difference? as in the FR5DTC over the F5DTC's?
    When I tried to the the F6DTC's I got some REALLY BAD misfires under boost. Switched back to the FR5DTC's and it ran like a champ.
    Jan 06 2007
    NH
    ^^I may consider that...
    pump
    Feb 27 2005
    North Wales, PA
    turn the boost down and see if the misfires go away. you could just be blowing out the spark.
    Oct 30 2006
    B8 A4 Avant 6spd
    I just started running the Bosch Sidefire F5DPOR's. Significant improvement over the ngk bkre6e's.
    -18 718 GTS
    Jan 06 2005
    san diego
    fr5dtc's are too cold, i've tried them and prefer the f6's.
    Jan 06 2007
    NH
    too cold for a 28 could be ok for a 30r though correct?
    Jan 06 2005
    san diego
    possibly, i've got a set of new fr5's if you would like to try them. pm if interested.
    Jul 07 2004
    socal
    Quote Originally Posted by creechsa4 View Post
    Hey, any plans to hit Fontana next weekend for Battle of the Imports? Even if you dont want to run in a class they have a lane just for fun runs, would love to see what times you can run.
    Jan 06 2005
    san diego
    wish i could this month i'm working weekends...
    Feb 13 2007
    98 A4
    Chicago
    so does anyone know if the resistor part could make a difference?
