The right rear camber didn't even change. Honestly, I wouldn't worry about it too much, you probably wouldn't even notice the difference. Its only 0.4* off from being within spec.
But it doesn't even look like he tried to adjust the rear right camber. Usually when u adjust toe, your camber will move so slightly. But you adjust camber first before toe. I checked on my alignment machine computer, looked at the illustration, and I think your camber should've changed. Might wanna take it to another alignment shop.
I aligned my girlfriends 98 avant and was able to get everything in spec. Her car has the stock sport suspension, but I could see I got a lot of adjustment left. Your front camber is non adjustable but they make those aftermarket adjustable upper bushing to make them adjustable... I wouldn't worry about it.
