Results 1 to 14 of 14
    Senior Member Three Rings therox182's Avatar
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    now what's leaking?!! help!
    I was unloading my car after food shopping and noticed a little puddle under the passenger side of my front bumper. I had just had the AC running (which i just recently had recharged) so i figured maybe it was just water. After I unloaded i decided to check it out, and it wasn't water. It was clear, but it was kinda slippery and greasy. I took off the lower grille by the pass. fog light to see if i could find the source and i did. once you take off the grille and pull back the black plastic which directs the air toward the intercoolers, there's what looked like a braided wire of some sort with a fitting on it. i'm not really too sure what it is/does, but im hoping maybe you guys can point out what it is.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: now what's leaking?!! help!
    Sounds like your headlight washer system is leaking.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    it didnt seem like washer fluid though. it was oily, but not engine oil. it was starting to build up on the inside of the bumper and some of it dripped out and onto the driveway. i'll try to snap a picture when i get a chance
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by therox182 View Post
    Yeah, picture would help, that was just a guess about the headlight washer. Could be pentosin from the power steering system too.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    is pentosin clear?
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    i thought pentosin was green.
    sounds like water from the AC system/washer system.. there is nothing on the car that uses clear fluid. otherwise.
    unless your cooling system has a VERY light mix of coolant to water then it would feel oily and look almost clear and colorless
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by JDM EJ1 95 View Post
    I think if you're looking at it in volume(in the reservoir), it appears green, but I'm pretty sure it pours yellowish to clearish.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    alright idk if i can get a camera to use today since i dont have one of my own. but i took another look at it. i'm not exactly a connoisseur of automobiles so forgive the lack of knowledge. this braided wire i'm talking about connects into whatever the black radiator thing is on the front in front of the main radiator. is that for the a/c?
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Stupid question, but did you touch the ground and the liquid? If it was water and hit the pavement, it will get greasy from the pavement.
    --ADam
    Have questions? E-mail me.
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    well i touched it off the ground first, noticed it wasn't water, then reached up under the bumper and felt it again. and i think the "black radiator thing" i was talking about earlier may be the a/c condenser possibly?
    Sep 14 2006
    14 GLI
    ^ That's a fair guess ... It's either water, coolant, or a mixture.
    --Adam
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    this is the connection that i'm talking about!
    Jan 29 2007
    08 S4 00 S4
    MD
    A/C line
    Apr 17 2007
    2001.5 s4 tip
    Los Angeles, CA
    alright cool thanks guys
    now what are the odds someone knows the part number to replace that line?
