Results 1 to 13 of 13
    Sep 19 2007
    seattle
    CEL now off..should I still be worried?
    Some of you read the other thread about my check engine light came on for the 2nd time at about 1000+ miles. The 1st time (came on at 164 miles) was due to Oxygen Sensor and dealer replaced it...
    The 2nd time came on shortly after I pressed the *tool symbol button* on the gauges display/dash while driving... Manual says that's the 'RESET' button... I was wondering if the Check Engine Light came on because of that? It was on for 2 days and now it's off... Should I still take it to dealer? If it comes back on again, then it's just like the 1st case..the light would be off for days and came back on again...probably another Oxygen Sensor problem...
    Thanks...
    Jan 24 2008
    West Coast
    Re: CEL now off..should I still be worried?
    You have warranty - you may as well get it checked.
    Moderator
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    Quote Originally Posted by cellg8 View Post
    You just gave me a flashback... As i replied in your other post that my warning light for a burned tail light came on as i was driving home after picking up the car... i remember fiddling with that tool button as well which may have triggered it since my tail lights are tip-top and i never saw that warning again...
    Im thinking we that might be what caused your warning light to come up as well...
    Either way, SoCal is right.. warranty = just have it checked.. its free!
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Sep 19 2007
    seattle
    Thank you for the replies, gentlemen. Maybe someone can try to press the 'tool' button while driving to see if that'll set the CEL on?
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    you're under warranty, you should be good :P but i'd vagcom it none the less
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    On a brand new car don't even ask about it- straight to the dealer for every issue no matter how small. You want everything documented in your service records - EVERYTHING!
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Sep 19 2007
    seattle
    Ok guys, sorry for wasting your time.. The CEL came back on again. I'll make an appt with dealer. Thank you!
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    It's not a waste of time. You have a new car and you want it to be right. I'd just take it in and let the dealer work it out for you. In the meantime just enjoy it as much as possible. I know that these little annoyances suck, but that's life. Cars can be close to, but never are perfect.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Let us know what the dealer says....
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Nov 04 2006
    05 S4
    LI, NY
    The check engine light is just an illumination device to let the consumer know there is or was a problem. It will set and store a code in the ecu that will NOT go away until it is cleared. And NO the tool button will not set or reset the actual code. If the cel is just on....that means that the ecu detected some problem that happened for a millisecond or so and is not happening again. If the cel is blinking then that mean the problem is happening at that very instance.
    When you start your car every time your ecu will perform a series of tests as long as your vehicle meets the criteria. Meaning your engine coolant temp must be under 150 degrees or your throttle position must be 10% or less.....that kind of stuff. If your cars meets those standards (different for each test) then your ecu will perform that or those tests on your cars emmisions/fuel/ignition systems. And if the ecu sees something that isnt working the way its supposed to....then it makes a note. If it happens a second consecutive time, then it will store a code in the ecu and set the cel to "on"
    If you are driving and a week later the cel goes away.....that doesnt mean that the problem is fixed.....it just means that it might not be happening under your driving criteria.
    without a doubt get it checked out....weather you vag com yourself just to know what the code is or just bring it in to the dealer.
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    If it is indeed an O2 sensor that might be covered under warranty for 8 years by federal regulations since it is part of the emission controls system. That is just a guess though...
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Registered Member Three Rings
    Jul 22 2008
    2006 S4 25th Anniv. Ed.
    Fed Way, WA
    Dude, did you get a clear bra while the car as in at Barrier today?
    http://i234.photobucket.com/albums/e...ProfileDay.jpg
    "I think I'm going to get metal legs."
    Sep 19 2007
    seattle
    Hey guys, thank you for the input!
    Dealer just called and said it's the same problem as before - Oxygen sensor... so they're going to open what's called the 'Tech Report' and talking to AUdi about it.. Sounds serious...
    Stormin, it was great to see you! So you'll be Audi sales? Dude did you see all the handsome RS4's they had out there? The black one looked amazing!
    No, it was not clear bra... I already have that. It was a dent I wanted the gentleman to fix.
    I actually went in to look for you at waiting area but you weren't there? At training, huh?
