Results 1 to 8 of 8
    Jun 05 2007
    San Jose, CA
    get smog done with SSautochrome?
    Hi all,
    i would like to get some info on getting smog with SSautochrome downpipe and exhaust. what kind of cat converter do i need? will i pass smog with just replacing the resonators on the SSautochrome downpipe? do i need to relocated the O2 bungs on there?
    thanks in advance.
    Aug 29 2007
    Santa Clara
    Re: get smog done with SSautochrome?
    do you have a cat in there right now? Any CEL? Most places will fail you on the visual for certain parts, and an aftermarket downpipe certain will raise some red flags.
    Jun 05 2007
    San Jose, CA
    I dont have cats at this moment. Im going to cut the resonators out and replace with cats.
    however, im not sure what kind of cats do i need, i was told that i cant use regular cats since the car is OBD2. is there certain spec of the cat that i need to follow?
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    this is exactly why i run a hfc
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Aug 29 2007
    Santa Clara
    Quote Originally Posted by ahwest View Post
    More than likely you will not pass with no cats, especially a visual inspection. I don't know if your technically allowed to move where the cats go, so I would think it would need to go in the same spot it came from (aka in the downpipe).
    Do you have the stock downpipe? It's probably easiest to either swap that back in, or purchase one and swap it. Should be cheaper than buying new cats and swapping them into your system. A little bit of work every 2 years, but I think a better alternative than hacking up your current setup.
    Veteran Member Three Rings papuc14369's Avatar
    Apr 06 2008
    NorCal
    totally off topic but how do you like your SSautochrome Dps?
    did they fit ok?
    i have a set that im selling but if they are decent then ill just keep them.
    what are your impressions?
    2001.5 Audi S4 - Santorin Blue - Stage 1 & dearly missed - RIP
    2000 Audi S4 - Nogaro Blue - Tial 770r - SOLD
    2001.5 Audi S4 - Black Avant - Bone Stock - SOLD
    2001.5 Audi S4 - Nogaro Blue Avant - Stage 3 RS6 Turbo - Daily Driven
    2000 Audi S4 - Laser Red - Sold
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    some places only check for codes being thrown. Thats how it was when I did it in Vegas. I might of got a lazy ass tech.lol.
    Train Hard, Go Hard, But always be Humble.
    Senior Member Two Rings Rau's Avatar
    Dec 19 2007
    2001 Audi A4 1.8T Quattro
    San Mateo CA
    Nevada's emissions test is vastly different from ours here in Cali. the techs here are super anal.
