As most of you know, my clutch and trans has been giving me all sorts of trouble in the 4 months that ive owned the car. I finally got everything squared away around a month ago, and its been performing flawlessly for the past 700 miles. Well last night i decided to launch it since the clutch was broken in and everything seemed to be doing good. I did two mild launches at 2800-3krpms and only took it half way through 2nd just to make sure things were good, and everything went fine. So i decided to do a more aggressive launch from 3500rpms and take it into third. The launch was great, the shift to second was spot on, but i decided to short shift third(around 5krpms) just to be safe...i didnt shift it hard but it still grinded when i tried to put it in third. So i put it in neutral and cruised to the turn that goes back to my house.
I dropped it to 2nd for the turn and it went in fine, went to shift to third and it acted like it didnt want to go it. It was hard to even get out of second, and getting it into 3rd was really hard. Now im thinking its either a syncro or slider, which isnt exactly what i need right now. I was hoping it was the slave cylinder or linkage, but that was just hopeful thinking because the symptoms dont add up. If it was either of those then the problem wouldnt be isolated to 3rd gear.
Do you guys think im right in my assumption that its the slider or syncro?
