Results 1 to 7 of 7
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Rear brakes cooking
    I just put new brakes on the rear of my B6, new rotors/pads. I didn't have the special tool so I just turned then pushed the pistons in with some other tools. Anyway, just took a drive today, stopped a light, smelled a horrible smell, got to the office looked at my rears and they are cooking... loads of heat and both are going purple :( Is it possible/known issue that the hand brake cable might get stuck? This is the only thing I can think of because I can't see how both rear calipers get stuck at the same time.
    Thanks
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Rear brakes cooking
    Make sure your pads are installed correctly again. It's easy to have the spring push them off where they need to seat if this is your first time doing your rear brake pads. If you didn't take the caliper off to do this your ebrake should not have changed. If you did, verify the spring is put on the correct way and there is nothing binding up the cable...
    Aug 14 2007
    Ottawa, ON, CA
    Will do thank you
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Did you have to force the caliper back on? It sound like the pistons didn't get pushed back enough.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Buncha motorcycles
    Memphis, TN
    you said you didnt have the tool? so you did you get them back in.. you could have damaged them possibly
    APR Stage 2/AWE Intake
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Also make sure you did not twist the brake line when putting the caliper back on. This will cause the brakes to heat up much faster than normal and smell pretty bad.
    Buncha motorcycles
    Memphis, TN
    would that keep the piston from retracting?
    oh i cant wait to put on my ferodos tonight! im sure its going to be a huge improvement over this sponges i got now (hawk ceramics)
