Results 1 to 11 of 11
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Thumbs up During clutch replacement, how often is stock Flywheel shot?
    Ok so my clutch is out, and I've decided to go ahead and do slave cylinder while i'm at it.
    My car is coming up on 98k miles, stock clutch.
    Can I be confident in buying a clutch kit, and just reuse old flywheel, or what? It is the dual mass flywheel I believe.
    I know I can go with SB clutches, but they dont resurface for free anymore.
    Plus I don't wanna have to send it in.
    ALSO, how much fluid does transmission hold, and is it same fluid as brake fluid?
    Thanks
    ~J
    Mar 12 2008
    Portales, NM
    Re: During clutch replacement, how often is stock Flywheel shot?
    Bump please. I have to make a decision on this on 2 hours.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I believe it is best practice to resurface the flywheel, since the teeth could be rounded, or replace with new when doing a new clutch.
    Buncha motorcycles
    Memphis, TN
    you can usually find a resurfaced one in the classifieds or another one you can send in before doing yours... what is southbend charging now>?
    tranny holds about 4 liters ( i had the center differential out too though, others have told me like 3.5 liters)
    make sure you get new center driveshaft bolts, flywheel bolts and pressure plate bolts and have a 10mm and 12mm triple square/spline drive socket and a full set of allen head sockets
    APR Stage 2/AWE Intake
    Mar 12 2008
    Portales, NM
    Yes, I'm just trying to figure out if I should replace flywheel, or have resurfaced.
    Buncha motorcycles
    Memphis, TN
    YES! mine looked fine, but it was more worn down in the middle but i couldnt tell till southbend ground it down even
    Mar 12 2008
    Portales, NM
    Quote Originally Posted by Papachristou View Post
    PM sent with better details
    Buncha motorcycles
    Memphis, TN
    it may not be "shot" but it does need to be resurfaced.. especially if you have drove it to where its not driveable anymore
    Mar 12 2008
    Portales, NM
    Should I do release bearing and release fork also, along with slave cylinder?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I resurfaced my flywheel.
    -Doug
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by jbrown7815 View Post
    Throw out bearing is typically included with a new clutch. The fork isnt under any wear, no need to replace it
