Results 1 to 40 of 41
    Veteran Member Three Rings ubermidget's Avatar
    Dec 08 2006
    Boston, MA
    full rs6's on their way
    finally ordered my turbos, full rs6's from vast
    prince and mike have always been very good to me and their products are above and beyond my expectations. Turbos should be here in a couple weeks so then i can start puttin it back together.
    If anyone needs k04's PM me, will be out of the car on saturday
    while i got the motor out:
    034 low comp HG's
    hot tank the heads
    ceramic coated manifolds
    RS4 y pipe
    Custom Vast tune
    Vast Water meth
    etc maintenance
    hopefully shell be fast
    EPL Stage 3 Aquamisted
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: full rs6's on their way
    nice cant wait see some numbers
    Oct 31 2005
    Ashburn
    Sounds good, so your not doing rods? Does this meen your going with a conservetive tune?
    - Instagram: @Sinister_rs5-
    Apr 05 2007
    awesome! i'm happily jealous.
    Senior Member Three Rings team_soy's Avatar
    Apr 30 2008
    florida
    Congrats...what tune are you going with?
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    let me know if u need help with your car bro...ps i want your asp downpipes
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Sounds great. Keep us posted and please make some videos. I want to go RS6 eventually and want to see other peoples luck with it.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by RolledMySTi View Post
    Why RS6s? I think GTs/Single Turbo option would be better at that price?
    - Clint
    Dec 08 2006
    Boston, MA
    im using vast for the tuning.
    right now im not doing rods since i just want to get the car running
    in the spring im going to do rods, supertech heads, full rs4 intake etc....maybe do an rs6 hybrid
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    Rs6's are only a grand more than k04's.
    To the OP- if I were you, I would wait on the meth kit, save up the money for rods, and then get the meth hooked up. This way you can really unleash their power asap without having to hold back.
    J Fonz Stage II+
    Senior Member Three Rings RxDlr's Avatar
    Nov 21 2006
    Skokie
    i really hope that jhm can get the rs6 turbos worked out by spring for tip's
    2007 s6 (present)
    2002 s4 (Past)
    Stage 3: VAST fueling| VAST TCU | RS4 SMIC's w/ APR hoses | milltek true dual exhaust | piggies | 710n dv's | apr bi-pipe | vogtland c/o's | hsport front and rear sways | rs4 grille | piano black trim | cc mod | EuroGEAR CF trunk and hood | RS4 reiger front | 18x8 bbs rs-gt
    Account Terminated Two Rings wreckedimolas4's Avatar
    Jun 11 2008
    silver b5 stg 2+ 95 m3
    almont
    i can get rs6ss for $2700 and i wonder what marc can make these rs6 cars with rods heads and cams run??????
    Jul 06 2007
    San Jose, CA
    GT's are more money and RS6 is more than enough power for the street. My car is my daily and sole vehicle and I want something streetable. I don't need to race 1000cc bikes.
    Dec 08 2006
    Boston, MA
    update:
    pulled the motor out this afternoon
    k04s are in better shape then i thought, no shaft play, d/s is perfect, pass. is just leaking oil out of the inlet PM me if anyones interested
    RS6's will be here in a couple weeks...hopefully be running by thanksgiving since ill at school in NH
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    w that hardware, she will definitely fly!
    thing is... doing rods later...? not sure about that one. you might be replacing a lot more than that if you run the car hard.
    also, im not sure if you realize how much work that is... to get the car running, then to put her down to get rods/heads done. basically, you'll have to uninstall it way past the turbos, and then there is down time from the motor being at the machine shop etc. you may just want to buy and build a block in parallel n then swap everything over, otherwise, you wont be seeing your S for a very long time.
    so do it the first time, or do it on the side, otherwise, expect to be w/o the car from spring to winter, lol. well, maybe it wont be that long, but itll be pretty a while. also its a lot of work.
    GL!
    Dec 08 2006
    Boston, MA
    yeah im still up in the air about the motor build......im gonna see how she goes on the stock motor with some goodies.
    defintly doing rs4 intake, fuel rail etc....so basically want JHM's setup w/ RS6's. and since ill have the low comp HG's i can add a lil more timing then stock. its just a street car for my personal enjoyment. not a drag racer or anything maybe a couple highway pulls to see what she can do against w/e. although i would like to see my car vs. gregs once im done and tuned......haha
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Quote Originally Posted by ubermidget View Post
    by the time your done i won't have my GT car but you can gladly race a few other GT25 or GT28 cars i tuned in NY :P see if you can keep up
    I can take my bros PJ K04 car out if anything, would be interesting to run a RS6 car, since i haven't raced any other Stage 3 S4's anywhere yet also Maybe one would want to give me a highway pull somewhere in NY or CT?
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Quote Originally Posted by 2001S4NY View Post
    ill be glad to beat you
    Long Island, NY
    Quote Originally Posted by BurnAll4S4 View Post
    k so give me a run PJ k04 vs PJ K04
    Sep 27 2007
    hate on me <3
    alright lets do it. but you might want to bring out the GT28 car since i trap 2mph higher then that too. :)
    Long Island, NY
    my GT28 car is retired and for sale, im sorry but i have confidence in a K04 car lol.
    ps your trap speed isn't impressive
    Long Island, NY
    also why don't you post some logs of your car im sure people want to see what makes you so fast other than the "secret goodies"
    Sep 27 2007
    hate on me <3
    lol neither was yours thats why its retired and for sale.
    nah but i let off at the end of my run because lebanon has 2 lines and it fucked me up so i stopped at the first like a retard, the 2nd line is about 30 feet later, thus the low trap.
    anyway, let me know when you want to do this.
    <3
    Sep 27 2007
    hate on me <3
    Mar 14 2007
    michigan
    <3
    So what your really saying is you should of went at least 10.9-10.8, I didn't see your car lift in the rear or lower in the front anywhere in that run nor did it appear to slow down
    Sep 27 2007
    hate on me <3
    who knows. im just stating facts. it shows in the logs too. if you can see a car shift a small amount at night 1320feet away not even zoomed in, i give you props bro. in all honesty. lol
    Oct 30 2006
    B8 A4 Avant 6spd
    +2 would love to see some of them logs =).
    And a video of this race.
    -18 718 GTS
    Jun 14 2007
    2000 S4
    Connecticut
    Uber... congrats, let me know how it is maybe we'll meetup if you're up for that when everythings all done I would love to know how the car feels. I may be doing RS6 turbos down the road later on in college when I have time to take the motor out again and build it up for the RS6's.
    Active Member Four Rings
    Dec 11 2006
    Boston
    Quote Originally Posted by wreckedimolas4 View Post
    doh
    Last edited by Das General; 08-24-2008 at 08:36 PM. Reason: Forgot I have to be nice.
    Stage 3+ RS6's
    Mar 14 2007
    michigan
    You can clearly see you didn't lift nor does the motor die off anywhere, post the logs lets see this freak of nature.. I doubt you will post them as it seems people that ran a weird number usually don't post logs anymore for one reason or another...
    Sep 27 2007
    hate on me <3
    what can you clearly see? the fucking finish line isnt even where the time board is. you sir, are EDITED FOR BABIES. in the video it doesnt even show the end, it just shows the time.
    http://www.youtube.com/watch?v=lctCSYLlMuI
    theres a little video to show how far back the line is compared to the board. watch when the time shows up.
    you think you know everything and have something to prove. instead you come off like a EDITED FOR BABIES. no one was even talking to you or about you.
    EDIT: this really shows how far the lines are from the board, and it shows the 2 markers at the end, like i said, i let off at the first set.
    http://www.youtube.com/watch?v=1xJbXrf5iEk
    want me to make you look stupid some more?
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    they would go real well with your gt2871 s4 spoolin.....
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Dec 11 2006
    Boston
    If you let off in the end, why didn't you say that in your first post?
    Now all of a sudden your trap speed is low, so you tell everyone you let off?
    Stage 3+ RS6's
    Sep 27 2007
    hate on me <3
    yea theres a lot of shit i dont say...because i dont care....
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    go Greg! SSP FTMFW!!
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    how much do u want for ur k04s pm please
    Jun 11 2008
    almont
    Quote Originally Posted by ///M3 TO S4 View Post
    hey they go good on my other s4 to wipe out you shitty and monster truck looking s4
    Dec 11 2006
    Boston
    looking at the video again, you can even hear the car still motoring away... in no way did you get off of the gas.
    Stage 3+ RS6's
    Jul 06 2007
    San Jose, CA
    What do all these post have to do with the op's post?
    For op: You aren't going to get it running til Nov!? I was hoping for some quick results.
    Dec 08 2006
    Boston, MA
    well ill be at school in NH and the car will be all the way in CT....so the work will go slow. well see though
