Results 1 to 9 of 9
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    did ECS tuning send me the wrong N75 valve?
    The one I took off the car is part number 078-906-283-B
    The one they sent me is part number 058-906-283-F
    The only thing different that I noticed when I installed it was that the connector was facing the firewall instead of the passenger side of the car like before... I took it for a spin and boost would climb to 17psi and then taper off to 15.
    Will this valve work with the S4 or do I need to get it exchanged?
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Feb 22 2007
    Earth
    Re: did ECS tuning send me the wrong N75 valve?
    Anybody?
    Feb 10 2004
    2009 A4 2.0T Sedan
    Did you contact ECS and ask them? They're a pretty helpful and friendly group.
    Feb 22 2007
    Earth
    No, they are closed right now.. I'll contact them tomorrow...
    Dec 06 2007
    Calgary, AB, Canada
    That's the wrong valve, but it may still work ok.
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Stock should be the same P/N. Call up ECS -- they're usually very good about this sort of stuff.
    --Adam
    Have questions? E-mail me.
    Sep 14 2006
    14 GLI
    ps - 2 moderators and the admin of the site in 1 thread ... you are so lucky
    Veteran Member Three Rings RAyala2.7T's Avatar
    Mar 08 2005
    Austin, TX
    It seems like you have an F valve off the A4. The B valve is obviously stock s4. either way I would still contact ECS to make sure that it is safe if you just want to keep running it.
    Rob - 2000 Audi S4 VAST Stage III
    Feb 22 2007
    Earth
    Thanks, I figured something was fishy about it as the connector was in the way of the accordian hose so I had to take the valve off the valve holder and its just hanging there in front of the accordian. Ill call them tomorrow. Do you think they will overnight a new one? I told them in the comment section that it was for an S4.... when I ordered i ordered it from the list of items in the S4 category, not A4.
    Quote Originally Posted by RAyala2.7T View Post
