Results 1 to 11 of 11
    Registered Member Two Rings
    May 02 2008
    B5 S4...Nogaro cuz its faster
    DC
    calmed down a bit...now help me finish this crap
    alright guys i just posted up i was going to snap because i couldn't find the location of my boost leak...well i bit the bullet and bought an air compressor, and on top of that, became a beast at building pressure tester
    anyways, i sprayed water in the region with the air running through, and couldn't see any bubbles, but i certainly traced down the leak underneath the TBB and vacuum line to the left DV. what could it possibly be?? heres a diagram
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: calmed down a bit...now help me finish this crap
    What year is your car? If it's a 2000 or 2001 it's probably your f-hose.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    Quote Originally Posted by RolledMySTi View Post
    it isn't a 2000. the y-pipe is the updated one.
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Did you do all of the installation of these parts?
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    May 02 2008
    DC
    oh snap my bad...this is a pic off the internet i used for reference...it is indeed a 2000 and i thought the F hose was located next to the firewall.
    is it the F hose, is that what it is there?
    May 02 2008
    DC
    oh and what is the part # on the f hose, or what can i tell them its called.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by alosh View Post
    078 133 784 AJ but look into a silicone upgrade or the home depot metal f-hose. It's kind of a pain to change so you only want to do it once if possible.
    Dec 06 2007
    Calgary, AB, Canada
    Yup, 99% chance your F hose is FUBAR.
    Established Member Two Rings kodycobra's Avatar
    Jul 15 2008
    00S4,07 ZX14,05 AcuraTL,Z32tt
    Jefferson City, Missouri
    Hell yeah! I'd be checking that F-hose as well. I just replaced mine last week with some brass fittings and such that I bought from Westlakes(Ace) hardware.
    Solid F-hose FTW!!
    Jul 04 2007
    00 s4
    danbury
    f-hose. mines shot also. does anyone know if it can be replaced under warranty since its going in anyways? might as well do it for free while i still can if its possible and don't have to deal with it now, atleast
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    get the samco f-hose.
    -Luis
