    Senior Member Two Rings xmoox's Avatar
    Aug 11 2008
    2000 audi s4
    Portland OR
    I discovered an oil leak
    So I just discovered i have an oil leak. Its either a cam seal or tensioner so im going to tear the whole front off and try and replace it myself. I have a friend whos a mechanic who is going to try and help me. the work for someone to do it was 1000 bucks that just too much. If i was to do it myself and pay my friend it would be like 150 bucks. My friend usualy works on other german cars but hes worked on an audi a4 1.8T and replaced the timing belt. Should we try to do this job cause i know if we do it wrong we will end up having a job that costs 5000 bucks. Hes changed 50 timing belts on other cars. I know I will need some special tools looking through the repair manual but it seems pretty simple. Any advice.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: I discovered an oil leak
    If you and your buddy know what you are doing go for it. It shouldn't be too hard if you have the right parts.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Sure it's not the valve covers? If so, it's an easy job. Cam seals aren't much worse.
    --Adam
    Have questions? E-mail me.
    Aug 11 2008
    2000 audi s4
    Portland OR
    Quote Originally Posted by 1997gtx View Post
    --Adam
    its an oil leak in the front right is there a way to get to those parts without removing the front if there is let me know cause i really dont want to rip the front apart.
    Senior Member Three Rings b5rs4's Avatar
    Aug 30 2007
    bmw x5
    winter springs, fl
    i don't think you have to take the front out to replace the cam seals... I'm getting ready to do this and I don't know yet if is the valve cover or the seals but either way you don't have to take out the front or am I wrong I don't know anyone care to share their knowledge.
