**i started this last week and have been taking pictures of the progress along the way. here is a breakdown of my progress**
Yesterday i started the build on my trunk for my stereo setup. I decided i to start a thread to walk you guys through the process so that anyone else who might be interested in doing something similar could have some insight.
to start off, this is similar to how i will build my setup
yesterday just began phase 1 of the entire build. i decided to build the box that will house the subs, and then build everything around that.
i started off by stripping out the trunk of all of the carpeting. you can see my current amp i have in there, which powers all of my speakers. this amp will stay, but will be mounted down in the spare tire well, so it will not be seen.
a few days prior i took some measurements, so yesterday i was able to just trace it out on the wood and start cutting
i then began assembly of the box
here you can see the box fit in the trunk. perfect fit.
after i test fit the box, i laid the plexiglass on top, and drilled the holes to mount the plexi
i then cut the holes for the subs, and began spackling the inside of the box. the box will be textured much like the wall of an inside of a house, and painted white.
i also drilled 5 holes in the top of the box, which will be for 5 LED lights. the lights will light the inside of the box.
the plan tonight is to finish painting the inside of the box, and hopefully begin part of the false floor, which will have the amplifier and capacitor flush mounted into it.
the stereo setup consists of 2x 10" Kicker CVR subwoofers, Kicker 750.1 amplifier, and a Capacitor.
the entire setup will be finished with dark blue suede which should set it off nicely, matching the exterior of my car.
hopefully more updates tonight
