Results 1 to 8 of 8
    Active Member One Ring coders11's Avatar
    Jan 28 2008
    B5 A4 1.8TQM
    Lansing, MI
    exhaust bolt and spring mia
    About a week ago i started hearing a metallic rattle from under the car during acceleration and whenever i would hit a bump. Finally got the car on a lift and the bolt and spring the hold the piping to the bracket have magically disappeared so my DP is just sitting next to the bracket and rubbing all day long. anyone know where I could pick up the OEM parts or am i going to have to head to the hardware store?
    I guess I should mention its an 01 a4QM
    Jan 21 2005
    sf bay area
    Re: exhaust bolt and spring mia
    yup i lost one too. the part at audi were like $100 [yes really]. so hardware store it was. get a long bolt, big spring and a nut. this way you can use the extra nut to double nut the bolt to the nut welded onto the exhaust. mine's held tight for a few thousand..
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    My spring is lost but the bolt size is M8X50. Now it sqeaks like hell, what spring did you use?
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Hmmmmm my whole peice broke..Im not running one i need to put one on.(i need the whole bracket though :( big problems for me--
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    so THATS what causes the rattle?
    hahahaha, i feel like an idiot, i guess i better put mine back in.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jan 21 2005
    sf bay area
    i just measured the gap, got a spring about an inch longer, long bolt, couple stainless washers.. and an extra nut.
    there's a bracket down there [trans side or exhaust side, i forget which] that has a captive nut in the bracket. i just pieced it together, and used a second nut to lock the bolt so it can't back out.
    Jan 21 2005
    sf bay area
    oh.. check your cat / dp bolts that they're tight. mine had loosened to finger tight.
    Jan 28 2008
    B5 A4 1.8TQM
    Lansing, MI
    i checked all the other bolts from turbo back and they are all ok. looks like im headed to the store. thanks for the info
