    Jun 25 2008
    South Florida
    QUESTION!!! Regarding my gearbox/transmission
    I have a 05.5 A4 2.0T FWD TIP btw...Whenever i start the car up and put it in drive it starts off nicely then after a while as i give it more gas...it starts to jump to S and back to D and back to S and so on, on the indash lcd screen and it keeps doing that until i turn off the car and turn it back on. Why is it doing this to me!!!! And sometimes it cant read when i go into N or R.
    Established Member Two Rings STaSIS_2.0T's Avatar
    May 20 2008
    2008 STaSIS/Audi A4
    Chicago
    Re: QUESTION!!! Regarding my gearbox/transmission
    Sounds pretty messed up. Never heard of it. Go to an audi shop and get it checked out, it'll be cheaper than the stealership. Unless you have an extended warranty?
    STaSIS/GIAC ECU | ITG ProFilter | EvolutionRacewerks SMIC's | STaSIS exhaust | STaSIS/Koni/Vogtland suspension | STaSIS/Alcon 355mm Mono4 brakes | Volk CE-28 19x8.5 | Toyo T1-R 265/30 | O.Z. Superturismo GT 18x8 | Dunlop Wintersport 3D 235/40 | JHM short shift kit | ECS snub | RS4 rear sway | RS4 pedals | S4 shift knob | RS4 grill w/s-line chrome surround | VMR vent boost gauge | 034 Intake Pipe | CoolBoxMod | Hardwired 8500 X50 w/"OEM" mute button |
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 09 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Ever since the black plastic that hides the gearshift mechanism stuff below the knob broke I've been having issues with the display not showing what gear I'm in, and inorder to make it show up, and for tiptronic mode to work I have to slide it over, move it to - then + and slide it back to D, and it shows up on the display and allows me to go into Tip mode, so I think that might be the problem, a loose track or something in the gearshift area.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Jun 25 2008
    South Florida
    Yeah im gonna take it to the shop saturday =(
    Jun 25 2008
    South Florida
    The PRNDS Lights in the indash screen blinks...when i try to change it.
