Results 1 to 7 of 7
Thread: Paranoid?
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Paranoid?
    K04s just went on ( k04's were NIB), and theres blue smoke coming from the back of the car. No shrieks, no cel, vag reveals nada.
    Is this normal? If normal how long would you think the smoke would last for? Any other trouble shooting is appreciated.
    All Red/Yellow plugs were removed from the K04s during install. No oil lines are kinked.
    Heres the setup. AWE Fueling(set to stock), AWE intercoolers, and K04s (NIB), this is on a 2001.5 S4.
    Talk to me people, Am I paranoid?
    B5 S4 AWE Stage 3 - sold
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Re: Paranoid?
    Did your KO3's blow? If so you might have some oil left in the downpipes.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Nov 23 2007
    Columbus, OH
    Re: Paranoid?
    nope the k03's did not blow
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Paranoid?
    mine took a while to stop blowing some leftover oil from my mishap.
    id drive it for a little while.. get it up to temp ( it takes the exhaust a while to heat up enough to burn whatevers in it)
    dont beat it up .. just drive it normal and see what happens.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Nov 23 2007
    Columbus, OH
    Re: Paranoid?
    Quote Originally Posted by JDM EJ1 95 View Post
    thanks man, i got the car set to stock mode and i plan on keeping out of boost for a little while till everything is expanded and set. Hopefully, the turbo seals are not the issue. Last thing i want to f-ing here is replacing good k03s for bad k04s, hopefully this is not the case and its just intense paranoia
    can anyone, confirm or deny smoke after install and to what extent?
    Dec 06 2007
    Calgary, AB, Canada
    Re: Paranoid?
    It's normal to have some smoke from the oil they put in the turbos at the factory. After running the car for about 10 minutes, it should stop.
    Just FYI, I have a customer's car sitting in my driveway right now with the engine out, waiting for the K04's to come back from BW. I installed them, then removed them after realizing that oil was getting into the exhaust passages of the turbos BIG TIME. Every time you fired up the car you'd burn half a quart of oil.
    Nov 23 2007
    Columbus, OH
    Re: Paranoid?
    smoke has cleared, must have been the oil that came in the turbos and any residue.
