Results 1 to 33 of 33
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Building a quiet exhaust for BT
    I am just starting my BT plans. Suspension is now done.
    I want a nice quiet exhaust that still flows OK? I don't want to call attention to my car driving around the parking lot at work or have a overly obnoxious drone on the highway.
    I was looking at the apr for B6's and that is 3" and supposedly not much louder than stock. I wouldn't mind more note when I am hard on the gas but I lived with loud exhausts before and I am pretty much over it.
    Well the single glass pack and side outlet on my Chevy 350 was sweet.
    So what are the parts (muffler, Pipe size, resonators) that I need to create a decent free flowing exhaust that won't rob too much HP.
    I will probably weld it up myself for fun and learning.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Building a quiet exhaust for BT
    Three letters, APR!
    I had a custom exhaust with two resonators and it was still louder than my resonated Apr.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    You need to add a few letters my friend lol...
    Milltek, there is no quieter system than a Milltek, regardless of make/model... Plus its 2.75" which is bigger than almost all the systems out there
    Established Member Two Rings ricebeater's Avatar
    Mar 02 2008
    98 a4 1.8TQM
    Malvern, PA
    neuspeed from 034 its only 750 and its not too bad. I dont know on a BT Im just saying for a KO3. It might be your best bet for a BT from the piping size stand point.
    1998 black 1.8t A4 QUATTRO
    MODS:S4 front bumper:S4 gauge cluster:S4 seats:S4 Grill:VDO boost gauge:Forge SMIC:Neuspeed Exhaust:Forge Spltr DV:18"x8" ADRs:
    Coming Soon: AWE DTS, A/F and OP Gauges, two tone paint job, lowering springs and more...
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    I kinda want to build it custom. do you know what mufflers would work to aproximate an apr, millitek or 034?
    Jun 04 2007
    Austin/DFW, TX
    forgot about miltek. Custom will not be as quiet as apr or miltek so don't waste your money.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    keep the cat - my only advice
    Oct 27 2007
    In the lab
    Quote Originally Posted by aytheory View Post
    why do you say that?
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Yeah going to do a race cat. I just want it in the ball park of the APR with available off the shelf mufflers. Am I missing something? will the performance suffer over the Apr with off the shelf stuff?
    its all a matter of the mufflers right? I put restrictive mufflers on it it will be quiet. I don't and it will be loud. The rest is just pipe.
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    I think he says keep the cat because without it The exhaust will be much louder. It acts as another resonator.
    I have run with a hollowed cat before and it is louder than with the material in it.
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Quote Originally Posted by 317ssayzarc View Post
    the cat quiets the exhaust note on these cars a lot and it also eliminates the droning. to the OP if you are looking into going BT with a custom exhaust and want a performance gain it is going to be noticeably loud no matter what.
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    I recommend Milltek with a test pipe or high flow cat. Mine sounds perfect with a test pipe and I like my exhaust quiet also. It opens up nicely when I want, but nice and quiet (basically stock like with a deeper tone) during my daily routine.
    You can get it pretty quiet going custom, but it will be noticeable.
    Jun 04 2007
    Austin/DFW, TX
    Ok, previously I had a 2.5" exhaust with stock downpipe. It had 2, 18" resonators, and a testpipe, and was way louder than the APR. The magnaflows even had an inlet of 2.25. So smaller diameter mufflers wont help at all.
    Seriously, dont waste your time and money, just get a milltek or APR!!!
    My 5-Speed Swap DIY
    - B6 USP
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Whats the secret of the militek or apr? Specially designed mufflers?
    Jun 04 2007
    Austin/DFW, TX
    Gotta understand that there is more to it than just the muffler. They use thicker metal with nice mandrel bends and tons of R&D.
    My 5-Speed Swap DIY
    - B6 USP
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Quote Originally Posted by biketsai View Post
    Right but you are ruining my excuse to buy a welder.
    Apr 22 2007
    Riverbank, Ca
    I have a borla 2.25" exhaust behind my APR stage 3 and it has a 3" test pipe...
    It is REALLY quiet for my tastes, but gets loud when you are deep in the boost/rpm's
    2 borla resonated mufflers, about 18" long...
    I'll go 2 3/4 or 3" later on, I'll put 2 maniflow mufflers in the system (or one cherrybomb and one magniflow), and a HF Cat (removable maybe) along with a cutout (or removable exhaust from cherrybomb on back) after the cat and cherrybomb.
    When under no load, it should be fairly quiet.. under load it should wake up and be loudish.
    Oct 27 2007
    In the lab
    Quote Originally Posted by AudiRacerS4 View Post
    Well a BT with a cat is pointless imo, each to their own
    Feb 27 2005
    North Wales, PA
    gutted s4 muffler and a resonator. Mines too quiet. i still have a cat on though
    Jun 04 2007
    Austin/DFW, TX
    Not trying to ruin your welding plans or anything, I just want you to get what's right for you the First time. I was like you a while ago and thought there couldn't be a difference, that's why I went custom.
    My 5-Speed Swap DIY
    - B6 USP
    Oct 28 2006
    haha i know that i'm just saying it quiets the exhaust. I woul dnever run a cat with a BT...hell i didnt run a cat on my K03 or K04 either
    Oct 28 2006
    yeah but custom is less than half the price of a milltek or APR exhaust. I paid $350 for a full turbo back exhaust.
    Feb 27 2005
    North Wales, PA
    the muffler makes a huge difference. steal a stock s4 muffler and gut it. A 3in exhaust and its really not much louder then stock.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I have a GHL 2.5" Turbo Back w/ HFC and I thought it was not that loud until I heard a Borla yesterday with a TP. GHL is much louder than the Borla. I'd love to have a Miltek or APR for stealth now. The Miltek is 2.75" and purrs while driving then opens up when stepped on it. The GHL does sound impressive and the popping makes up for the noise.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 27 2005
    North Wales, PA
    my borla was very loud when I had it on my elim. No cat and BT really changed the tone.
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by Poopie View Post
    For sure, BT makes it soooo deeep. Its rediculous how drastically the tone changes.
    My 5-Speed Swap DIY
    - B6 USP
    Jan 21 2006
    6MT BT Avant Ti
    RI
    K03 is a pea-shooter muffler.
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    I have APR but with the resonator removed.
    Much better
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Senior Member Two Rings NK2007's Avatar
    Mar 25 2008
    2000 Audi A4
    Ft. Collins & Colorado Springs
    My exhaust is custom, full 3" turbo back, with a race (hi flow) cat and 2 mufflers. one of them is a magnaflow and the other i am not sure if it is a second magnaflow or a different company.
    I love the sound! Its quiet at normal driving, a little louder than stock, but at wot it has a very nice tone. Not raspy or ricer sounding at all.
    |00 A4 TQM|K04|Revolver Cams|Greddy FMIC|Custom GIAC|Full Custom Exhaust|OEM RS4|S4 Rear|S4 Interior|HID|
    More to come!
    F.S. Rieger Side Skirts in Silver- will trade for S4
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Quote Originally Posted by nebone22 View Post
    I love my Milltek too. That is the best one I have owned. Nicer than the Stebro, Scorpion or B&B Triflow (I believe they now make APR's). The fit was perfect, the sound is great, the clamps they shipped out with it sucked. They have since been replaced. But the exhaust was well worth the extra $$
    2014 A4Q Red w/ black optic black interior
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    Quote Originally Posted by tdn View Post
    i Recommend Milltek With A Test Pipe Or High Flow Cat. Mine Sounds Perfect With A Test Pipe And I Like My Exhaust Quiet Also. It Opens Up Nicely When I Want, But Nice And Quiet (basically Stock Like With A Deeper Tone) During My Daily Routine.
    You Can Get It Pretty Quiet Going Custom, But It Will Be Noticeable.
    I Have A Shotgun Testpipe With My Milltek Exhaust And Its Quiet...
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    make sure you get two mufflers in there. NOT one muffler and a resonator. Without a second muffler esp. with a test pipe the sound will be too loud for daily driving. trust me.
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The reason that exhausts like the Milltek are quiet is tuning. We worked with Faurecia on a few projects and learned a lot. Cars have a few resonant frequencies. So do exhausts. So do sunroofs. Tune the port to the wrong size and flow and you get a nasty resonance. Close your windows, open your sunroof all the way, and go for a drive - you'll find a resonant frequency. This is an example of what happens inside a ported subwoofer enclosure below the port tuning frequency. Drop the back windows an inch and the resonance goes away. It doesn't take much to effect rather large tuning changes.
    The oems tune the exhausts to whatever they want them through fancy math and trial and error. The aftermarkets do the same and it is often the same people doing the actual work. Changing the size of a can (cat chamber, muffler chamber, piping) changes it's frequency. By controlling all the variables they can do some crazy things like giving signature sounds to the Pontiac Grand Prix and Nissan/Infinity line. They got the same signature sound in the FX35 and 45 even though the engines are very different. It just took some tuning.
    http://www.faurecia.com/pages/about_...ic_package.asp
    Unrelated but worth checking out:
    http://premium-attitude.faurecia.com/
    Jim
    I Do Werk.
