Results 1 to 12 of 12
    Established Member Two Rings Eurotrash8's Avatar
    Apr 10 2008
    Calgary
    Painting Filler Plate
    Kinda dumb.....I bought the wrong color ( Grey) and I need a black one. What would I use to paint it matte black?
    Registered Member Two Rings
    May 01 2008
    Pomona CA
    Re: Painting Filler Plate
    get a can of spray paint and try it.. cheap way to do it
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    spray paint will chip.
    Use black plastidip spray
    its a black plastic spray. wont chip and its matte black
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    DUH! an Audi
    los angeles, CA
    ^yup
    Apr 10 2008
    Calgary
    Where would I get plastidip from....Home Depot?
    Thanks guys!!!
    Quote Originally Posted by Elohite View Post
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    you could get it there I'm pretty sure but yes if you want it to last you need plastic dip
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    paint it gloss black
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Plasti-dip should be by the glue in the paint section. I love the stuff!
    The usual things!!
    Resistor Install
    Apr 10 2008
    Calgary
    I have a few other questions for the people who have used this stuff.
    1.) If I paint just the filler plate how close does it match the rest of the grill?
    2.) Is there any type of prepping that I will need to do ie: sanding
    3.) Should I paint the whole grill including the chrome trim?
    The last question I did a search of if I can remove the grill without taking the bumper off. Can anyone clarify or send me a link of the easiest way to remove?
    Thanks so much to the above AZ's
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    To take the grill of you need to take the bumper off...
    But to take the filler plate off, you dont have to remove the bumper...Just 6 screws and you are ready to go...
    Feb 16 2008
    Oakdale, MN
    1) It matches alright, not 100%, if you are worried paint the whole grill.
    2) No need to prep it, just make sure it is clean and dry.
    3) I did mine and like it, but that is your call.
    If you search B7 front bumper removal you should be able to find atleast 3 threads about taking it off.
    The usual things!!
    Resistor Install
    Mar 19 2008
    the matte black does NOT match the rest of the grille. gloss black does match very well. a lot of people do seem to love their matte black however.
    2019 S5 BO.SS
    2009 R8 6 Volt :)
