Results 1 to 10 of 10
    Senior Member One Ring
    Apr 01 2008
    03 GTI, 04 SIERRA
    Norman, Oklahoma
    factory 04 exhaust
    might just be a stupid question, but I am in the process of waxing my car when I get to the bumper I look in the exaust opening and see that after the muffler there are two pipes coming into one. One of the pipes looks like it has a butterfly valve that has a linkage coming out of it. I know the RS4 has this on the dual pipes that I think is controlled through the sport mode button. What is mine for, and what controls it to open and close?
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: factory 04 exhaust
    The S4 flaps are controlled by engine vacuum. If you get under the bumper you'll see a tube that runs from the flap control to a vacuum line on the bumper. The flaps are there to control the drone under 2000 rpms buy circulating the exhaust gas through the rear muffler. When you romp on it the flaps will open and exhaust will be straight through improving flow.
    The S button in the RS4 essentially overrides this feature.
    Incidentally this is why aftermarkets systems have the drone issue...
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Apr 01 2008
    03 GTI, 04 SIERRA
    Norman, Oklahoma
    Great info, thanks for your help.
    Dec 05 2006
    So. Cal.
    I actually think that the flap is there to make the car sound meaner at idle and quieter at highway speed.
    At anything below 1700 rpm, both tubes are open allowing exhaust gases to exit. When the motor revs above 1700 rpm's, the flap closes down one of the exit pipes to keep the car quieter.
    Hope this helps.
    Apr 11 2008
    Pasadena, CA
    From the Audi Training Manual 921603 available on the Bentley site if you subscribe:
    Audi RS4 Exhaust Flap Control
    A further difference is the layout; one exhaust flap is
    located downstream of each of the rear silencers. The
    exhaust flaps are fitted to give the engine a sporty sound.
    Low-frequency droning noise at low engine RPM is
    prevented. At high engine RPM and high exhaust gas flow
    rates, flow noise and exhaust back pressure are reduced
    by opening the additional cross-section.
    The exhaust gas flaps are closed at idle, low engine load
    and at low engine RPM.
    Function
    The exhaust flaps are switched by a vacuum actuator.
    Both vacuum units are switched by an electrically
    activated solenoid valve. The exhaust flaps are switched
    according to a characteristic map.
    The factors of engine load, engine RPM, gear selected
    and the shift signal from the Sport button are used to
    plot the characteristic map.
    For example, the exhaust flaps are opened at idle when
    the Sport button is pressed.
    The Avant Garde
    Veteran Member Four Rings CHECKERED's Avatar
    Aug 17 2008
    05 B6 S4, BMW F15 X5
    Southern NH
    C6 Z06 Corvettes and 2008+ C6 with factory upgrade exhaust have the same thing…but you can override it with an aftermarket switch, makes the car sound bad ass at low speed cruising
    B6 S4 Winter Beast: Supercharger, Carbonio-hybrid Intake, Fast Intentions DP & CB, CF Vented Hood. Susp:PSS9 Coilovers, Hotchkis F&R sway bars, Brakes: B7 RS4 Front (w/LW rings) & rear BRK, SS lines. Snow tires.
    Daily Driver: BMW F15 X5 M50d clone, DUDMD tune, water/methanol injection, 38mpg highway
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Do a search for "exhaust flap mod" in the B6 forum. You'll come across a number of AZers (myself included) who have essentially "plugged the lines" with everything from golf tees to screws. Not sure if its actually done anything noise wise but hey, whats life without a little DIY modding?
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Apr 01 2008
    03 GTI, 04 SIERRA
    Norman, Oklahoma
    thanks guys this is all great stuff.
    Apr 01 2008
    03 GTI, 04 SIERRA
    Norman, Oklahoma
    Quote Originally Posted by CHECKERED View Post
    I had a new vette in the shop a couple of weeks ago that had the exhaust mod that was controlled by a wireless fob, amazing how much it changed the sound
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    i disconected my flappers and under hard throttle you get a raspy sound...
