Results 1 to 4 of 4
    Veteran Member Three Rings Spongebob05's Avatar
    Jan 23 2007
    06 S4 - 95 R1 Raven -
    Austin
    Code to troubleshoot.
    Anyone has the link or know where one is hosted to check on the description of one's code ie. P2198 means =
    Thanks
    Sponge
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: Code to troubleshoot.
    Spoogebob,
    Need to check the 1st O2 sensor in bank 2.
    From Bentley:
    P2198 18630 O2 Sensor Signal Stuck Rich Bank 2 Sensor 1
    G108 - Heated Oxygen Sensor (HO2S) 2
    Bank 2 is on the drivers side of the engine compartment. The connector is right most connector behind the coolant expansion tank and has 6 pins (the others have fewer.) The Bentley manual goes on about how to check the sensor resistance and input voltage, but that's too much to post up in here.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Senior Member Three Rings Mello's Avatar
    Jan 07 2008
    '04 S4, '06 GSXR 1K, '06 Apex
    http://www.bentleypublishers.com/tec....dtc.table.htm
    I didn't see it go to P2XXX though...
    Apr 11 2008
    Pasadena, CA
    Quote Originally Posted by Mello View Post
    Sometimes you pays your money and gets your code...
    The Avant Garde
