Results 1 to 3 of 3
    Registered Member One Ring MikeSammons32's Avatar
    Aug 12 2008
    1998 Audi A4 Quattro 1.8T
    Georgia
    Installing a boost guage
    It was brought to my attention that a boost gauge should be one of my first mods. What are some good brands and how hard is it to install? Should I let someone else do it? I'm no mechanic but i feel like I can pickup things pretty quick.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: Installing a boost guage
    AWE or Podi would be my recommendation. As for the install, it is very simple. Just attach wires to a ground and a power source under the dash, run the air hose through the firewall into the engine compartment, use t-fitting to attach to vacuum hose on intake manifold and you're done
    {99.5 Avant}
    Dec 05 2007
    The Search Button is there to help you. I posted in your other thread with a DIY link. On a scale from 1-10 (10 being the most difficult), it is a 1.
